PVM20M4E Sony monitor geometry adjustment
  • zen
    • 511
    Hi all
    Not sure how to access on this set.
    Can anyone help ?
  • R_J
    • 9555
    Re: PVM20M4E Sony monitor geometry adjustment
    The easiest way would be to download the service manual, but you can access the service menu by simultaneously pressing [ENTER} and [DEGAUSS]
    • zen
      • 511
      Thanks RJ , now have access to manual.
      • zen
        • 511
        Started off by replacing caps known to cause issues on this model (see pics)
        Also discovered a 4.7MF,160V behind LOPTX with high ESR
        Set up geometry best I could, after customers fiddling.
        Enter service mode by first pressing MENU button, then DEGAUSE & ENTER together.
        Once in service mode use MENU & ENTER to move through different adjustments.
        Arrows up & down to alter values.
        DEGAUSE to store. Might need to press it twice.
        Waiting for the retrophile to turn up with his Nintendo WI for the final verdict.
          by momaka
          03-15-2023, 10:17 PM
        • FZG
          Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
          by FZG
          Hello there, helpful forum people!
          I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
          On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
          The original part...
          05-10-2023, 11:54 AM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
          by Rick_1234
          Good evening, gentlemen.
          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
          https://drive.google.com/file/d/1L6S...ew?usp=sharing
          Things I tried
          - Bought a new AC adapter thinking that was the problem but the problem...
          06-22-2024, 04:44 PM
