HP1955 Board Burnout - Is it Fixable?
  • harveywilson
    • Jul 2010
    • 6
    Re: HP1955 Board Burnout - Is it Fixable?
    I purchased a transistor replacement kit from eBay for a few dollars and today replaced the damaged parts. I'm pleased to report that the monitor is now up and running, and not smoking (yet!).
    Thanks to all that took the time to offer advice in this thread.
    • retiredcaps
      • Apr 2010
      • 9271
      Good job. Hopefully you resoldered the all transformer pins?
      --- begin sig file ---
      --- end sig file ---
      • seanc
        • Nov 2008
        • 1319
        Can you tell us what parts you replaced?
        Part numbers & locations?
        • Jox-CZ
          • Feb 2014
          • Czech
          Hello all,
          I saved this monitor, my colleague want throw it to electro waste
          In my case was burned only one side of the backlight circuit.
          I renew these parts:
          2xQ808&Q809 - [Original C5707] replacement: 2SC5707
          1xQ805 - [Original J598] replacement: IRFU9024n
          1xQ804 - [Original-SMD t06 - PMBS3906] replacement: BC857B
          The monitor is like new.
          Only the replacement IRFU9024n has a higher RDS.
          It cause there is higher temperature on the 9024.
          J598 - 45°C x IRFU9024n - 55°C
          I hope it isn't problem
          So, I thank you for the advices in this thread ;-)
          Some photos: ==>
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Well done !
            I hope you took note of the advice about re soldering the transformers.
            Its best to remove the old solder and resolder each pin. Do the same for the blue capacitors and for the other c5707s
            We have had many members who didnt do this and had to return a few days
            later as the 5707s just replaced had blown again.
            It is the bad solder on these boards that causes the problems
            • Jox-CZ
              • Feb 2014
              • Czech
              #26
              With the transformers it's a different story
              We have in the work one same monitor HP1955,
              but it made horrible whistling sounds.
              So I changed the transformer from the burned board.
              There is some differences between the boards. Here you can see =>
              The result is, that no monitor don't whistling.
              I have the desoldering tool HAKO484so it was piece of cake ;-)
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
              • canadaboy25
                Panasonic TC-P54VT25 No image. A or D board?
                by canadaboy25
                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                01-17-2021, 01:06 AM
