I got this used, and the first time I plugged it in it worked fine. The next day it was 2 seconds to black, and every time since. The first thing I tried was plugging in some external ccfl's. They came on dim - only about 1/2 the tube lit up, then off. As I replaced caps and resoldered some areas, I got differing results, sometimes the tube would be a little brighter, sometimes dimmer, but always goes off.
I replaced the smaller cap in the inverter section, C306, 33u, 50v, Nichicon, and c206, 1000u, 16v cap in the bottom left corner. The other caps tested ok, and the ones I replaced weren't too terribly bad on the esr meter. (note: I replaced c206 with a 1000u, 25v - didn't have a 16v handy.)
On the top of the board between the transformers there is some discoloration, and on the bottom of the board, the components at u303 and u304 look strange, kind of shiny on top. I can't read any identification markings on them. I think it is possibly a mosfet?
The transformers tested ok with the ring tester, and I resoldered some connections. I don't know where to look next, and don't want to just replace u303 & 4 (assuming I can figure out what they are) if something else needs to be checked.
Thanks.
Thanks.
I couldn't believe I was that lucky, and just to make sure, I removed the jumper and put it onto C404, and the problem re-appeared. And just to really make sure, I put the jumper onto C419 and again 2 sec to black. So the problem is in the C415 circuit. I tested the connector - good, then swapped the ccfl's, and no change. My next thought would be to replace the cap I shorted over, except I have no idea how to figure out what to use to replace it. Any ideas?
I am hoping to place an order tomorrow, and would love to include these parts if anyone could help me in determining what to order. Thanks.
