CMV CT-934D won't power on - secondary voltages disappear
  • retiredcaps
    • Apr 2010
    • 9271
    Re: CMV CT-934D won't power on - secondary voltages disappear
    Originally posted by Rtech
    Although 'logic' says the fault is on the 'Logic' PCB(pardon the pun..).I assume that if you had another Logic PCB,you would have tried that to confirm that is the case ????.
    I got this monitor for free from the local ad. If I had another one identical monitor, yes, I would have tried swapping boards.
    Set up the PSU/Inverter ONLY..ie NO Logic PCB,Plug in the CCFL's,and on the connector which normally goes to the Logic PCB,apply Approx 3volts DC(from an external battery perhaps),between the ON/OFF pin and Ground.This will light the Lamps.HOWEVER I had lying around a little PC Fan,a Standard 12v,250Ma one,and a little experimenting showed that applying 12v to it, it actually took 62Ma,BUT applying
    5V to it the current increased to approx 160Ma,So with the Set up as above,if you have a Fan,or similar, put it on the same connector between the 5v pin and Ground.The question is DO the CCFL's light ???and the Fan spin ???
    Funny, I was thinking about a test like this for the last couple of weeks and what I have at home to do this.
    Thanks for the idea, I'll see what I can do to test this in the next few days.
    --- begin sig file ---
    --- end sig file ---
    • URAD_Harvey
      • Oct 2010
      Did you ever get it fixed?
      An old trick we used to use long ago was to use a 6V lantern battery in series with a resistor on the 5V supply line to limit the current just below operating current for the traces being evaluated. Then you take a meter and measure the voltage along the supply line traces, it will be a few micro volts higher at the source but will drop to zero at the short. Of course in those days the boards we were testing were 17" double sided - not these 4" 6-layer jobs.
      Let us know what you found out
      • retiredcaps
        • Apr 2010
        • 9271
        Well, almost 20 months later, I figured out the problem. I originally got the idea from momaka way back around Dec 2011 when he did a lot of detailed posts on troubleshooting the t-con boards.
        https://www.badcaps.net/forum/showpo...9&postcount=13
        He explained that smd ceramic caps fail shorted on the t-con boards. Somehow this gave me the idea to look at all the ceramic caps on my logic board (not t-con) and sure enough CP18 was shorted. See pic.
        It wasn't until March 27, 2012 that I actually replaced the ceramic cap with a 22uF 25V Samxon electrolytic cap. I took at guess at the capacitance value based on the size of the other caps on the logic board.
        Once I replaced it, all the voltages came up and stayed stable. I have been running burn in tests for the last 48 hours and everything works great so far.
          Those MLCC can easily be damaged due to poor handling during assembling of the board, or the board got flexed too much. I replaced those caps in T-CON, Inverter boards, main baords before, the bad part is that some time there will be 5~10 in parallel, and as always, the last one I remove to test will be the one that is shorted out, I can see cracks on the body using high magnifying glass to see.
          MLCC info
          https://www.badcaps.net/forum/showthread.php?t=19663
          • kallyd
            • Nov 2010
            Do you still have it after so much time?
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Still works and staring at it right now. It is on at least 4 hours daily.
              • tomodachi
                Lenovo Ideapad Gaming 3 15ARH05 NM-D191 processor voltages disappear at startup
                by tomodachi
                MB schematic and boardview
                https://www.badcaps.net/forum/troubl...86#post1802186
                This one came in with no display complaint.
                MB powering up with all CPU coil voltages of CPU and GPU present, appear to be drawing around 1 to 1.8 amps on boot cycle, then in 3 seconds CPU phases on PL3003,PL3002,PL3001,PL3000 disappear, leaving MB drawing only 0.25 amp with GPU core voltages still on.
                Trying to...
                10-03-2024, 04:21 AM
              • Capacitorial
                Powersupply has all the voltages - Monitor still no power
                by Capacitorial
                Hello guys,
                I have a Philips 240B7QPJEB. The monitor seems completely dead.
                I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                The weird thing is, that the Power LED is powered over the TCON board.
                On The TCON...
                12-28-2024, 02:12 PM
              • gjgib
                Help reading schematic voltages input/output
                by gjgib
                Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                05-06-2024, 08:11 PM
              • RossMoodley1967
                HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                by RossMoodley1967
                Hello
                Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                03-01-2024, 06:07 AM
              • karlp028
                MSI Z390-A PRO missing VCORE voltages
                by karlp028
                I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                Today, 01:25 AM
