Lenovo Ideapad Gaming 3 15ARH05 NM-D191 processor voltages disappear at startup
  • tomodachi
    • Apr 2012
    • 612
    • Turkey
    MB schematic and boardview
    https://www.badcaps.net/forum/troubl...86#post1802186
    This one came in with no display complaint.
    MB powering up with all CPU coil voltages of CPU and GPU present, appear to be drawing around 1 to 1.8 amps on boot cycle, then in 3 seconds CPU phases on PL3003,PL3002,PL3001,PL3000 disappear, leaving MB drawing only 0.25 amp with GPU core voltages still on.
    Trying to power off pressing power button, 10 seconds of pressing ends up with self reboot with same cycle.
    BIOS, EC firmwares are ok, CPU core IC RT3667 replaced, still same.
    No corrosion, nothing suspicious.
    Unit came in with very, very dirty and clogged fan, giving me idea of loose balls under CPU..
    Any ideas will be appreciated.
  • tomodachi
    • Apr 2012
    • 612
    • Turkey
    Update
    Mildly reflowed +VDDCR_VDD mosfets and two tantalum caps sitting across coils out of curiousity, motherboard booted succesfully, but after cool down it won't work again.
    Tomorrow I will do a full resoldering and tantalum replacement and let you know results.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Dying PCH due to overheating?
      • tomodachi
        • Apr 2012
        • 612
        • Turkey
        Do you mean CPU itself ? Yeah quite possible. Reball might help
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Its ryzen APU and its known to have dryball joint issue.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Before experimenting with reball,observe the status of 1.8V when core voltage disappears.
            • tomodachi
              • Apr 2012
              • 612
              • Turkey
              Thanks for the input. 1.8V was always present.
              This one worked just fine after resoldering CPU core mosfets. Been testing for a day, so far its working.
              • Capacitorial
                Powersupply has all the voltages - Monitor still no power
                by Capacitorial
                Hello guys,
                I have a Philips 240B7QPJEB. The monitor seems completely dead.
                I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                The weird thing is, that the Power LED is powered over the TCON board.
                On The TCON...
                12-28-2024, 02:12 PM
                Lenovo IdeaPad Gaming 3 15ARH05 Notebook 3 Specification for Upgrade or Repair
                This specification for the Lenovo IdeaPad Gaming 3 15ARH05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15ARH05 boardview and Gaming 3 15ARH05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 10:20 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • gjgib
                Help reading schematic voltages input/output
                by gjgib
                Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                05-06-2024, 08:11 PM
              • estabilito
                Acer Nitro AN515-55 weird behaviour on startup
                by estabilito
                Hi, I've just repaired acer nitro an515-55 with specs:
                i7-10750h, rtx2060.
                Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
                After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
                i've tried different bios, different vbios and same behaviour - clean windows install too.
                Do you have any idea?
                08-13-2025, 02:52 PM
