What usually dies first in a circuit?
  • Bishop
    • Apr 2009
    • 99
    I have repaired several LCD screens and recapped several motherboards, and I was just wondering.
    What part usually dies first, there's got to be a point where most damage occors first?
    What happened to the old re-set switch?
    Where did do it yourself before you call the factory go?
    In the early PC's the factory put in a re-set breaker inside the case so only the servicemsn could open it up and push it after a power surge. Warning labels were there to keep the buyer out.
    I was given a PC Friday to see if I could fix it by a friend. Nothing was out of place, nothing looked fried, but the mother board was dead. All the other parts worked in my test PC, but the MB?
    I worked in DATA for 30 years, 10 years in house before PC were available for the home or business, and our stuff was protected internally and externally. The trash factories put out today is surprising..
    Has anyone a clue? Is it always the caps the first to die?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: What usually dies first in a circuit?
    heat -> caps -> transistors/mosfets/regulators
    or poor soldering and running any of the components close to their specified max. limits from the factory..
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      If you are talking nothing breaks and it 'just wears out' then caps would be it.
      Caps and coils are about the only things that aren't solid state anymore and coils don't have liquid to dry up or chemicals.
      Mann-Made Global Warming.
      - Dr Seuss
      • Astonished
        Fixing the Charge Circuit of the Batteries of the DC Motor
        by Astonished
        Hi friends of electronics
        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
        Please help me fix this circuit.
        (the datasheet of the IC: https://pdf.datasheet.live/28...
        01-28-2025, 06:24 AM
      • RRice25541
        Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
        by RRice25541
        So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
        the color is all outa wack, like the settings have been corupted,
        I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
        so
        The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
        when i bring up the menu and type the pass codes to access either mode the menu disappears...
        05-13-2022, 10:44 PM
      • Tarot Superstars
        Short Circuit tester
        by Tarot Superstars
        Hello.
        I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
        The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
        Link
        The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
        https://www.youtube.com/watch?v=0eixDdCpiO4
        My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
        09-25-2023, 09:11 AM
      • Alimash
        op amp circuit function?
        by Alimash
        I am repairing a ups which doesn't turn on ,it has the following ICs:
        SG3525 used to drive inverter mosfets.
        couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
        A LM358 and TL074 for control mechanism and of course the uController.
        The SG3525 is shutting down every time the ups is turned on.
        I want your help to know the function of LM358 and TL074 in the system.
        I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
        07-31-2025, 07:45 AM
      • M1NEBLANK SHOW
        MSI B250 Gaming M3 Short circuit in CPU power supply circuit
        by M1NEBLANK SHOW
        Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
        (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
        Schematic and Boardview here
        04-04-2025, 03:57 PM
