P2317H not turning on
+ More Options
Posts
  • questore
    • Dec 2015
    • 479
    • csongrád
    Re: P2317H not turning on
    Originally posted by R_J
    It could be flashing for many reasons, no input signal, no backlights etc.
    >Goto #6
    I have to wait for a few days before i get the working power supply. In the meantime i was thinking. What if i test our theory by doing the following.
    Connect the two boards and also connect my lab power supply to 5v line where its low and let it draw the power from there when its plugged?
    I think it could provide a solution for our theory does it not?
    • questore
      • Dec 2015
      • 479
      • csongrád
      After hooking up the powersupply to the 5v with the main boards connected and plugged in, the voltage is still waving and goes up only to about 2.9v, maybe the two small electrolit capacitors on the mainboard are bad and cannot hold charge? Ordered an ESR meter for that (will be good for other things as well)
      Let you know when power supply board changed and what ESR meter sees.
      • questore
        • Dec 2015
        • 479
        • csongrád
        Got a new powerboard and it powers up fine, BUT...
        The picture on the panel is scrambled
        Plugged back and original panel picture and it fine with my board, so my LCD panel is bad also.
        Removed the panel back tape and LCD panel number is:
        M230F07V01_HF REV 0.0
        - Checked that board and no short to ground
        - No bad diode found
        - Fuse is ok
        Anyone can help diagnosing if it can be repaired?
        2 IC THAT IS on the board is sm4142 and lfm60a3
        reading after powered on:
        VON: 27,9V
        VSS1: 8,4 V
        VSS2: 9,8 V
        TVDD18: 1.8V
        TVDD12: 1.2V
        DVDD: 1,8 V
        AVDD: 10,42
        VCC: 5.08V
        D2P1 0,58 V
        D2N1 0,58 V
        HCT3 4,17 V
        VCST_S3 4,06 V
        CN3R_1 0,020mV
        CN3R_2 0,020V
        SCL: 5V
        RVC 4,6v
        CVC 1.03V
        R1 0.262
        RDV1 10V
        RDV2 4V
        CREF 4V
        • questore
          • Dec 2015
          • 479
          • csongrád
          After ESR meter is arriving I think i will try with this to solve the problem:
          https://www.youtube.com/watch?v=4HFHpzSQfj0
          • Woodsworth
            PS3 CECHC03 60GB YLOD Troubleshooting
            by Woodsworth
            I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
            START
            Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
            03-19-2024, 07:58 AM
          • Victor Petrovich
            Lenovo IdeaPad 3 15ITL6 doesn't start
            by Victor Petrovich
            I have laptop Lenovo IdeaPad 3 15ITL6 with Intel Core i3-1115G4. When I press the start button, LED light on the start button starts blinking 12 times, then stops and after some time starts blinking 12 times again. When it stops, all voltages are down.
            The motherboard is HS460 HS560 HS760 NM-D471 Rev: 2.0
            S/N: PF3Q0WTF
            The motherboard is not mine, also there were corrosion on the board which I cleaned.
            Methods of fixing like fully turning off the motherboard or starting only with adapter doesn't work. All testing were did only with adapter on.
            06-07-2025, 02:40 AM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Mustang67ford
            Sharp LC-50LB370U PS or backlights?
            by Mustang67ford
            Hello all. Working on a sharp LC-50LB370U. A few days ago, I turned the tv on and immediately left the room, came back in and tv was black. Turned it off then on and all good (didnt think much of it at the time) for about a week. Did the same thing again but stayed black this time. When turning on, the word "sharp" is dimmer than normal I think then tv goes black. I do have sound and do have a display with the flashlight test. I trided unplugging and also holding in the power button for 30 sec, no change. I opened the back up and the backlights do turn on to some extent for a moment...
            11-12-2022, 08:32 AM
