Do you wait to identify the bad capacitor and then order the replacements or do most of you have a ready assortment to choose from? I can see over time a supply developing but what should a beginner buy to have a likely replacement available ahead of time?
Buying Capacitors
Re: Buying Capacitors
It depends. I started out in April 2010 with the intent on fixing just one LCD. So I ordered just the caps I needed plus a couple spares.
Then I saw deals on Craigslist and Kijiji and got a few more LCDs to fix. Then I needed more caps.
The ones that seem to be replaced the most (looking through my bad caps) are 1000uF 16V and 470uF 25V.
If you are only going to fix this one LCD, order just what you need. If you like doing this, you will automatically accumulate more and more.
Originally posted by foxdenDo you wait to identify the bad capacitor and then order the replacements or do most of you have a ready assortment to choose from? I can see over time a supply developing but what should a beginner buy to have a likely replacement available ahead of time?--- begin sig file ---
--- end sig file --- -
I normally use Hitano EXR caps, and carry stock of:
470/10
470/16
470/25
1000/10
1000/16
1000/25
That addresses 95% of requirements in terms of capacity/voltage/dimensions for me.Friends don't let friends buy Samsung ....Comment
In Canada, shipping from ca.digikey.com is $8 CDN + GST + PST. So shipping could be as much as $10 CDN to get a 30 cent cap.
If you live in the USA, I believe digikey.com charges around $3 USD for shipping.
Originally posted by foxdenThanks for the advice, I guess I can buy a few of each of these. I really expected a much longer list. Seems like the problems for the most part must be related to these however.--- begin sig file ---
--- end sig file ---Comment
Originally posted by foxdenI am in the US. The shipping is really the reason for my question. I would rather order a bunch and pay one shipping than order one or two capacitors and pay a bunch to ship it.Comment
Originally posted by retiredcapsIn Canada, shipping from ca.digikey.com is $8 CDN + GST + PST. So shipping could be as much as $10 CDN to get a 30 cent cap.
My .02 Cdn....36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....Comment
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
- Loading...
