Dell 2000FP Blank screen problem
  • blargg
    • 51
    #41
    Re: Dell 2000FP Blank screen problem
    I've been trying to get my 2000FP working again, now that I have an o-scope. It's followed the same pattern several times:
    * When I power on, it shows the logo, then menus work, etc. Works for a few hours, then all buttons stop responding. Still works as monitor (as long as I don't turn it off), showing output from PC. Doesn't resync when I change resolutions. So the CPU has crashed, but all the video stuff is working fine.
    * If I unplug it and plug it back in, it generally just lights all LEDs and the backlight never comes on. Sometimes the logo appears and it freezes on that, or it freezes a few seconds after. If it manages to sync to video, it'll keep working as above.
    * Even after being unplugged for a day, plugging it back in gives the same LEDs. Curiously, if it's been unplugged for a while, it takes a few seconds before all the LEDs come on, but then when I unplug for a minute and plug back in, they come on instantly. It's like there's some state in there.
    * If I leave it unplugged for a month, then it works fine for a few hours.
    This leads me to believe that there's something more than a bad flash chip, and that switching chips is masking some other problem. Maybe a different chip puts different loads on things, or something like that.
    • blargg
      • 51
      #42
      I've found that the /RESET line to the flash chip is low. Tracing it to a couple of transistor inverters, I find that some control signal is low into the pair of inverters, when it should apparently be high. Holding the /RESET to flash doesn't allow it to boot, so I'm thinking that whatever is making the earlier control signal low is closer to the cause. It may also explain the LEDs delaying coming on if it's been off for a while, some capacitor somewhere discharging. I couldn't find where this control signal goes elsewhere on the board though.
      • sinip
        • Dec 2011
        • 18
        • Republika Srpska
        #43
        Start checking electrolytics capacaitors with ESR metere and replacing them. You'll have A LOT to replace. Then change EEPROM chip with the new one.
        • Unit
          • Oct 2013
          • Finland
          #44
          Well well, my monitor just quit itself. It first was black screen, after unplugged it returned normal. Then it doesn´t helped, and power light is two-coloured and can´t be switch off, only by removing power totally get it back to black screen.
          I read all this earlier messages and etc, and there might be some point in the others, but becourse this monitor runs quite hot, it can cause the solderings to break. Earlier work I used microscopes to find those kind of breaks (and fixed those), so lets look what those look like when I look solders on my own microscope. Worst case is that total memory-chip breaking, but it really dosn´t happen often, not if it´s properly placed away from heat and etc.
          And of course, capasitors are made NOT TO LAST forever, so if seeing cap that has top bulged, it means RIP for that cap.
          • sinip
            • Dec 2011
            • 18
            • Republika Srpska
            #45
            None of those I've replaced had bulged tops, after all those are SMD types so bulging isn't easily visible, if at all, but if you use ESR meter you'll see how bad the situation is. You can expect that 70% will need to be replaced.
            • sonic74
              • Jan 2012
              • 3
              #46
              Unfortunately, my 2000FP also got the all LEDs lit bug. And I'm not able to resolder TSOPs ;-(
              I'm also not sure whether it's really the flash, because very, very seldom it still starts up, but crashes later.
              I discovered quite some service manuals here. Interesting findings:
              Checking the clocks as per Dell 200FP trouble shooting.PDF:
              16 MHz clock:
              130 MHz clock:
              CON111
              1: RESET
              2: V3.3CPU
              There's even a serial console:
              CON103
              left: GND
              middle: TX
              right: RX
              Output when booting:
              Code:
              Booter v1.5
              C
              But it doesn't seem to react to input.
              High res PCB back side scan available on request.
              • neslekkim
                • May 2014
                • Norway
                #47
                thanks for the link to those manuals, did you find the password for the pdf for the inverter board?
                My 2000FP started now for an month ago to go black, the buttons work, the leds work, but the screen go black sometimes after 15-30 minutes, sometimes longer.
                I took the monitor apart, replaced two 220uF/25V capacitors on the inverter board (they was rounded on the end, and had an capacitance around 40-50uF according to an fluke87-v, my ESR meter did not manage to get anything from them)
                But after starting it up again, it continues to give me black screen from time to time.
                I notices that leaving the monitor connected (it's my secondary screen on an fx580), when it goes black, the computer still thinks it is there, when I unplug the DVI it notices its gone, so it seems like the mainboad of the monitor should be kinda ok?
                If I disconnect the monitor in windows, and leave it on, it goes to sleep after some time, the powerled goes orange, if I then connect in windows again, then I get picture, so maybe something is relaxing when it goes in sleep?, similarly when I turn it off, wait a minute, and turn it on, it comes back nicely.
                So, what next?
                The monitor is old, so I should probably just replace it, but it have no other faults.. (my primary, Dell 2408WFP on the other hand gets some vertical lines on the right part of the screen sometimes, happens exactly the same to 3-4 others at the office too.. )
                • sonic74
                  • Jan 2012
                  • 3
                  #48
                  Unfortunately not.
                  As you can see in Dell 2000FP interface BD.pdf on page 6, the 24C02 I²C EEPROM for DDC is directly connected to and supplied by the DVI connector.
                  • neslekkim
                    • May 2014
                    • Norway
                    #49
                    I found some solderings that was not so nice on the inverter board, there are two gray big capacitors (one is marked C16), resoldered those, and two inductors that are throughole (one is L1), resoldered those also.
                    The screen was used rest of the day, and still now this morning it is working, so maybe I'm lucky....
                    • Roman78
                      • Oct 2017
                      • 54
                      Hello, just created an account because my old and trusty 2000FP just died last week.
                      Originally posted by sinip
                      Yes, several people to whom I've sent the dump reported their monitors as fixed. If you can't fin original EEPROM, you can as well use 29LV800 instead.
                      Could you send me the file?
                      And can i still use the old chip or do i have to buy a new one?
                      And... about the ESR Meter. I own a Capacity meter like this one: http://img.tomshardware.com/de/2007/...geraet_big.jpg is that enough or is an ESR Meter better, because of measuring on the circuit board without removing the Capacitor? And what is a good ESR Meter?
                      • ohren
                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                        by ohren
                        Hello!
                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                        Measured voltages with no load:
                        After rectifier diodes
                        12V: 6.17 V
                        5V: 5.67 V
                        Secondary transformer pins AC measurement (really don't know if this says anything)
                        12V: 2-2.5 V
                        5V: 1.04 V
                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                        03-18-2023, 10:33 AM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
                      • x_orange90_x
                        by x_orange90_x
                        01-29-2025, 09:24 PM
                      • dennis_elx33
                        3PHASE STEP-DOWN Transformer in Check
                        by dennis_elx33
                        Hello All,
                        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                        Problem statement: Power tripped Off
                        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                        Action Done:
                        1) Replaced the faulty parts with good spare.
                        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                        12-02-2024, 06:52 AM
                      • hasel17
                        CH341a can erase and read but can't write and blank check
                        by hasel17
                        So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                        Code:
                        Checking for blank...
                        (Press
                        10-26-2023, 06:20 AM
