Sceptre x22wg-Gamer 22" LCD
  • mack505
    replied
    Re: Sceptre x22wg-Gamer 22" LCD
    No. Here is my philosophy.
    Let's take an extremely simple case. Take a monitor off the shelf, do a quick test, it doesn't work. Open it up, notice one cap is bulging. Replace the cap, test the monitor, it works, put the monitor together again. Elapsed time - 1 hour and $1.00 of parts.
    Now most of the caps came from the same company, or at least are of the same quality, and have been exposed to the same temperatures and similar stress. Replacing all of the caps would have taken an additional half hour, and an additional $5 in parts.
    Some of the monitors I repair are given to family members, but most are sold. Let's take the best case - I give one to my 12 year old Granddaughter. Now she's a bright young lady, she knows Grandpa makes mistakes. If the monitor dies in the next year or two she would politely ask me to fix it when I got a chance. Which means I would make it a priority job. And I would be looking at another hour long job to replace the next cap that died.
    A much worse case is if I had sold the monitor. Even with an ESR meter, I can't tell how long a cap is going to last. In particular, the small 22 - 68uF startup cap will fail without warning or visible signs. Now if a monitor I sold in the past month dies, I have a very unhappy customer who at best will insist I repair it FAST, and will probably badmouth me at every opportunity.
    In either case, it's worth half an hour of extra work and $5 in parts to make sure it's fixed the first time.
    Note the critical parameters - capacity, voltage, diameter, and height and I'll recommend suitable replacements.
    PlainBill
    1 million thanks! I am back up and running after replacing the 7 capacitors, under $5 total.
    The 7 items from Digikey were:
    1 - 493-1575-ND
    2 - P12366-ND
    4 - P12389-ND
  • FIXITNOW
    replied
    i will second that PlainBill
    the pile of items i have had come my way with the words (i had it fixed a few weeks ago at ******* repair shop) can you do a better job ??
    only to open it up and see the previous repair had done only a basic repair
    not even a reflow of the common d/j areas
    its sloppy if you want repeat work do a proper job
  • PlainBill
    replied
    Originally posted by mack505
    Thanks Bill, do you know how the other 3 are labeled? As C551, etc are?
    PlainBill
  • jetadm123
    replied
    Take look at post #1 of this thread.
  • mack505
    replied
    There are three more that you are ignoring. The small one next to the SMPs transformer is very important. If it fails, the power supply won't start. And in that location it gets plenty of heat. There are two for the inverter that should also be replaced.
    PlainBill
  • PlainBill
    replied
    Hi PlainBill, thanks for your response. I am planing on P12389-ND from Digikey. Is it just those 4? C551, C552, C554, and C664?
    I could not correct the red tint with adjustments. It was almost as if you had 2 of the 3 cables plugged in on a component video connection, like that. VGA worked fine though.
    PlainBill
  • mack505
    replied
    The recommendation is to replace all the electrolytic caps with the possible exception of the large (100uF, 450 volt) one. Use low ESR name brand caps, not junk from Radio Shack.
    A red tint is often the result of failing CCFLs, but since it only appears on the DVI input, that is probably not the issue in your case. Have you tried adjusting the tint using the menu?
    PlainBill
  • PlainBill
    replied
    Hi, my monitor would not power up at all, no indicator lights at all. Just prior to that, the led indicator would blink really slow interval, no display.
    I seem to have the bulging C551 and C552. Start by replacing these?
    Also, before I was just using the VGA as the DVI had a red tint to it. By the time I called support, I was out of warranty. Any ideas on that, now that I have it open?
    Many thanks in advance!
    PlainBill
  • mack505
    replied
  • hms1018
    replied
    @ PlainBill
    Thanks a lot. Works like a charm.
  • PlainBill
    replied
    Originally posted by hms1018
    Hello Everyone!
    Noobie here. I just Googled and came across your site which is very informative. I am trying to understand some things and know a little about others. I have just replaced my 2 bad caps "after over a year after taking it apart". I am attaching pics to figure out the dark spots on the back of the PSU, and I need to know exactly how the 4 (Pink and white)cords attach to the monitor into the other 4 cords wrapped in black tape.
    Dark spots: This is the AC input to the bridge rectifier. The only idea I have is that poor solder joints were overheating. I'd remove the old solder and resolder.
    Four cords: They go back togetherlike they were originally. You didn't label them?
    OK!! OK!!! When the power supply is sitting on the back of the panel, the pair from the top of the monitor go to the pair from the top of the power supply. It doesn't matter which way the two pairs go together.
    PlainBill
  • hms1018
    replied
    Hello Everyone!
  • PlainBill
    replied
    Originally posted by FranklinP
    I tested the ESR on all the caps on my Sceptre X22wg-Gamer monitor's power supply and C551 and C552 were the only ones that were questionable. In my case, like the pictures provided by severach in the first posting of this thread, my C551 and C552 caps were the only ones bulging.
    I decided that since my C551 and C552 were obviously failing (bulging) and the ESRs on the other caps seemed reasonable, that I was going to only replace the TWO caps.
    Total cost of my repair parts was approx. $5 from Digikey.
    My monitor is working fine.
    From severach's posting:
    >"Bulged caps on power supply:
    >C551, C552: CapXon 470uf 25v (runs at 5v, good ESR=0.05, bad esr>=1.1)"
    Ordinarily I recommend replacing all electrolytic caps, but would tend to agree that replacing only those which fail an ESR test makes sense.
    PlainBill
  • FranklinP
    replied
  • retiredcaps
    replied
    Originally posted by clowncarni
    Can anyone see if C551 and C552 are bad?
    Post 29 (caps) and post 88 (how to attach pics) are applicable in your case.
  • clowncarni
    replied
    Went to turn on monitor and got a loud pop noise. It cycles in 2 second intervals making a buzz. I figure a cap or two went bad on the power supply. Can anyone see if C551 and C552 are bad? Thanks
    http://i.imgur.com/v3wHU.jpg
    http://i.imgur.com/qozDx.jpg
    http://i.imgur.com/QTJn3.jpg
  • cammac725
    replied
    The dark spot (overheated?) on the board in photo 2 of the orig. post corresponds with component U4 (regulator?) on the other side of the board, photo 1. I have the same board with the same dark spot and my U4 looks like it overheated (not uniform in color). I also have some failed/bulging capacitors on the power board. I am thinking I'll replace the logic board also.
    Now if I can find one. Nothing on ebay.
  • Lew
    replied
    Originally posted by mockingbird
    I no longer have the screen, but I'm still interested if someone gets the DVI and HDMI working...
    Why didn't you end up also recapping the logic board? Not that you should, in fact, since it's working, I suggest you don't. It's very easy to destroy the logic board because it's a lot more difficult to solder than the PSU.
    Wholly because of my lack of skill and confidence. This was my very first effort at doing any circuit board soldering (ever) and my assessment of the difficulty level of the logic board was the same as you say, "a lot more difficult". So I tested the monitor after replacing the power board caps but before fully re-assembling it. Since it worked, I decided to call it a day before I destroyed it.
    I did go ahead and buy the caps for the logic board (that you included in the parts list) when I ordered the power board caps but just opted to call it a day while I was ahead. If it has problems later, I'll re-think it.
    Thanks again!
  • mockingbird
    replied
  • Lew
    replied
    Add another success story to the list!! I replaced the four CapXon 470uf 25v, the two Taicon 1000uf 16v, and the CapXon 33uf 35v and it's working flawlessly on the VGA.
    It's still a no go on the DVI and HDMI connection but I'm not going to pursue getting them to work based on mockingbird and PlainBill's experience to date with bird's connections, but I will stay tuned.
    Thanks again to all you guys!!! Also, the DigiKey experience was excellent.
    Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook 16 Specification for Upgrade or Repair
    This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 05:20 AM
    Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
    This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
    09-07-2024, 12:10 AM
  • Mad_Science
    Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
    by Mad_Science
    I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
    03-01-2024, 05:05 PM
    KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
    by momaka
    For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
    http://www.rmac.kingwin.com/products.../abt_650MM.asp
    I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
    What mostly drew me into buying it is its 2x PCI-E power connectors...
    03-29-2022, 11:34 PM
  • spirittoo
    Sceptre 48" TV backlight LED`s
    by spirittoo
    Trying to fix a backlight problem with a Sceptre 48" TV.
    I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
    So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
    Anyone know how I can remove those leds without damaging them?
    11-11-2023, 10:23 AM
