1 red vertical line, then a green or red line
  • mjk
    • Jun 2010
    • 3
    Hanns-g HC 194D. 2.5 years old. Started with 1 vertical red line after heating up.
    Replaced the bulging electrolytic caps. Okay for about a month. Then it reoccurred. I found that by pressing different areas of the top circuit board attached to the LCD, it would go away. The back casing is still off. Now I get 1 vertical green line at start up which goes away. Once in a while it may reappear or a red line may.
    Attached circuit board area image.
    Yellow circle seems to be a good pressure point.
    MAX1977.. is a regulator
    AR7 unknown
    AS15F... unknown
    SMD caps uF and v are all unknown.
    It should be against some law to manufacture, sell or install unmarked caps
    Any idea as to what may be causing the problem?
    Thanks, Mike
  • Tomthetech
    • Jun 2010
    • 3
    Re: 1 red vertical line, then a green or red line
    Could be a possibility that when you put pressure on that spot that you've marked, disturbs whatever is plugged in at the bottom. (Ribbon)? Check in that area, maybe remove and refit. Check for cracks.
    • lucky13
      • Aug 2007
      • 412
      Most likely where you were pressing were affecting the connections where you marked the word "TOP". There is a bad connection there somewhere....
      • cubytus
        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
        by cubytus
        Hi to all,
        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
        01-10-2024, 01:26 AM
      • otaku_nut
        Vizio E701i-A3 fixed but now has red vertical line
        by otaku_nut
        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
        08-19-2025, 06:11 PM
      • hoot
        One vertical green line on my AQUOS LC-70LE740E TV
        by hoot
        on my AQUOS LC-70LE740E LCD TV there is a vertical green line on the screen. (pictures below)
        Does anyone know what the issue could be?
        Up close it looks something like this.
        Can this fault be serviced?
        What I want to do is the following:
        gently pressing on the ribbon connections along the top and bottom of the panel in the area of that line. Pushing a driver IC onto the flex cable it sits on to restore the lost connection. When the problematic area is found installing...
        11-21-2021, 07:48 AM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
      • almarhum
        To fix laptop screen vertical line by working on its EDP cable
        by almarhum
        Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
        As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
        05-07-2024, 02:12 PM
