HP f1703 Monitor
  • zylcho
    Padawan Learner
    • May 2010
    • 52
    HP f1703 Monitor
    Powers on fine. Only displays VGA image for a second then turns off. Indicates there is no signal being received. Everything appears to ok on the graphics board.
    Now on the power board....
    I have noticed some bad solder joints on the choke coils and a bulging cap.
    Resistance on all caps on the board are the same (without removing)
    The worst thing is that I have a 19" HP which is doing the exact same thing!
    Any assistance will be greatly appreciated. Thank you in advance.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP f1703 Monitor
    The cap in picture 2 is definitely bulging. Replace that.
    I'm the last person that should talking about soldering, but it looks like the solder joint just above D207 has a line fracture. A good solder joint should like the one right of D207. The left most solder joint (next to the word CONN) also looks like it has a split crater.
    I think that yellow/brown stuff my be flux and not cleaned off? Someone else can verify or dispute?
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      Just saw this at
      http://www.lcdmonitorrepairebook.com/
      6) HP 15 inches fl503 (AOC OEM)
      Fault diagnosis: Dark screen after switch on lcd monitor.
      Fault location: Found the dry joints on inductors L201 on high voltage inverter board. (This high voltage inverter board has three inductors have the same dry joints).
      P
      • zylcho
        Padawan Learner
        • May 2010
        • 52
        VIOLA! That was it! Thank you for your time and consideration!
        Now as far as the bulging cap, all the caps on the board have same value in uf and voltage. When I checked resistance, they were all within a few thousands of each other. Does this mean that is is "showing bad", but will eventually go?
        Once again thank you!
        • retiredcaps
          • Apr 2010
          • 9271
          What was "it"? Please clarify so we know what fixed "it"?
          How did you test the caps? With an ESR tester? or DMM with the caps unsoldered? What exact reading did you get for resistance?
          • zylcho
            Padawan Learner
            • May 2010
            • 52
            It was the those bad solder joints on the "L" coils. The board had 5 on it but only 3 had those crappy joints. Heated and reapplied.
            I have a Fluke 16 DMM and was getting 1.651 on the K scale, with cap still on board.
            Thanks!
            • retiredcaps
              • Apr 2010
              • 9271
              Glad it is working. One down, one to go!
              Thanks!
              • seanc
                • Nov 2008
                • 1319
                Do replace that cap, if it's bulging, it has already failed. Piece of mind for a small amount of change that you won't have to open it anytime soon.
                  master hoarder
                  • May 2008
                  • 12164
                  • Bulgaria
                  You can only use a DMM to see if the caps a shorted, but you can't test them if they have high ESR or not. For that you need an ESR meter.
                  What brand and series are the caps anyways? The one in pic 2 does look a bit bulged. If it is, then it's probably a good idea to replace all caps from that brand.
                  • sam67
                    • 256
                    Originally posted by retiredcaps
                    Just saw this at
                    That is a very nice site and the free ebook is good ..I was reading the tips section and posted the link on this forum as it may help others as it did me.
