It had the famous inverter problem, first i had changed only 2 of the 4 C5707 , the other 2 seemed not in short, 1 FU9024N and the .22 160v cap that was bulged if i remember, but i had taken the other from another FP71G+, it seemed ok with capacity but ESR i can't test, finally the picofuse.. the strange thing: i had tested it for approx 10 minutes as i always do for a first test before reassemble it, it goes well, another time, months after i retested it remounted, it appeared the logo for 1 second then black screen, i opened it and found (if i remember) the picofuse shorted, some c5707 shorted, i think 1.. i have removed the fu9024 , i don't remem. why, but found that it had a factory defect, it had a thin metallic piece between two legs, if i touched the center pin in a direction it makes contact, in the other no.. now i changed this , all 4 c5707 and the fuse and when i switch it on it starts with the logo but no all lamps on, then disappear logo and starts a white shadow from the upper right corner, it becomes bigger.. there is a video i made with cellular.. not so clear .. if vga is connected it appears the image for some seconds then if i remember disappears or become dark and also strange boxes and stripes can appears before, i can also feel a burnt smell, after i decide to switch off.. in the video i have pressed on/off at least 1/2 times to be able to show something... what situation it is? Is possible that firstly the fu9024 don't touches between legs and all was ok, then after with a flection of the case it is become shorted and the result is this?
The video: http://web.tiscali.it/bps_impianti/Benq-defect.avi
