CCFL problem? Gateway FPD2185W
  • cacharo
    • Mar 2010
    • 5
    Long-time lurker, first-time poster. Thanks to the members of this forum for all the help you have already provided me.
    I have a Gateway FPD2185W which was recapped a few years ago with 2 seconds to black symptoms. Recently, this monitor began making a loud hissing noise and the picture has degraded significantly. I can see the input from the PC and it does not turn off automatically after any period of time. I have attached a picture and as you can see the right side of the monitor appears brighter than the left.
    The only reason I suggested CCFL was because the symptoms were not as I have experienced in the past. To date I have only needed to resolve 2 seconds to black issues. Currently, I do not have any pictures of the board as I have not opened it up yet.
    Thanks in advance to anyone who can point me in the right direction.
    -Cacharo
  • smason
    • 1652
    Re: CCFL problem? Gateway FPD2185W
    That monitor is notorious for bad caps. What kind of caps did you use when you re-capped. Could be some of them failed again due to heat.
    Without seeing it, hissing noise could be arcing on bad solder joints, or a transformer.
    Might be obvious once you open it up.
    I have one on my pile of monitors to fix, I haven't even looked at it, just ordered caps, as I KNOW it will need 'em. Caps should arrive on Monday. I'll crack it open next week and we can compare notes.
    • cacharo
      • Mar 2010
      • 5
      I will open it up and add some pictures. I swapped them with RadioShack caps, which I understand now is not best practice. Where did you order your caps from?
      • cacharo
        • Mar 2010
        • 5
        I was not able to figure out how to edit my original post to include these additional pictures -sorry.
        Smason, you are right. There are certainly some areas that are standing out. There is one 470uf 25v cap that was not originally replaced that has blown as well as the pair of 220uf 25v caps that are blown and caused a large burn mark.
        The 7 470uf 35v caps I replaced earlier still look ok to me, do you agree?
        I am too much of a novice to notice anything on the solder side. Do you see anything?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          minimum type of low esr to even consider is panasonic fc,nichicon pw,rubycon zl,ect.those xicons are not even close.replace them again along with the other blown ones.
          • cacharo
            • Mar 2010
            • 5
            Thanks KC, do you have a preferred online vendor? I doubt I can find them close.
            • smason
              • 1652
              I agree the 7 *look* ok, but if you're in there anyway, I'd do all 8, plus the others with known good 105 degree low esr caps.
              I get most of mine from Digikey (my 1st choice is the Panasonic FM series) or here on Badcaps. Any of the brands KC8 mentioned will be fine.
              • pedro
                • 199
                • AUSTRALIA
                -Cacharo
                Those RatShack caps WILL need to be replaced, regardless of whether there is another issue - which I definitely suggest there is. The pic looks very much like an inverter or CCFL problem. Once you have the monitor opened, try to locate the noise source. I would be looking at the following suspects:
                • inverter transformer (joints/soldering)
                • inverter transformer (other fault)
                • CCFL wiring/termination (arcing)
                but we will know more once you get it apart.
                Friends don't let friends buy Samsung ....
                • freelander
                  • Apr 2009
                  • 109
                  Trouble shooting with blown capacitors is going to be troublesome. I have many FPD2185W monitors and most will come back to life with a simple capacitor replacement. Although I agree that the 7 previous re-caps look ok, my preference would also be to replace all 8 of the 470 caps and you definitely are ordering 2 of the 220 as well. When you are ordering (and replacing) capacitors, the cost is so low that it just doesn't make sense to not do them all.
                  By the way, the bulbs in this monitor are on the top and bottom so if you are getting brightness to one side like your picture shows, you may very well have an issue with your bulbs AS WELL. You can open up the panel while you are waiting for the caps and have a look at both ends of both sets of bulbs. Post pictures if you are not sure. You will find other posts for this monitor that will discuss how to get to the bulbs and how to pull the boot back from the one end to expose the solder joint of the supply lines and the bulbs.
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Zeonalbasta
                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                    by Zeonalbasta
                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                    09-13-2024, 01:17 PM
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
                  • Gibon378
                    Problem with stopping audio and video for no reason
                    by Gibon378
                    PC Specs:
                    • CPU: Ryzen 5 1600
                    • GPU: GTX 1080 Palit JetStream
                    • MOBO: ASRock ab350 PRO4
                    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                    • PSU: XFX 650W (don't remember what model)
                    • OS SSD: ADATA SP920
                    • OS: Windows 10 21H2
                    Problem description:
                    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                    11-19-2022, 09:41 AM
                  • perzyk23
                    Lenovo T580 - LCD Panel problem - error 0288
                    by perzyk23
                    Good morning,
                    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                    10-25-2024, 12:42 AM
