Benq E2200HDA Monitor weird sound
  • arthurmod
    • Apr 2021
    • 7
    Hey,
    I have a Benq Monitor which has a strange weird sound coming from the PCB with the image flickering and then goes blank, after I re`power the monitor the image appears but with the noise and then goes blank after couple of seconds. LED is green, it doesn`t go on standby. Checked the cables, even the video card, all good.
    • 21209
    Re: Benq Monitor weird sound
    Which pcb do you mean,is the power board and mainboard seperate or in one. Whats the monitor model number,and the pcb
    • arthurmod
      • Apr 2021
      • 7
      Hey man
      I assume is the PCB, i didn`t opened up. Is a Benq E2200HDA.
        • 21209
        Originally posted by arthurmod
        Hey man
        Attached is the service manual, take it apart and post pictures of the power board.The big capacitor could still have a high voltage in it so be carefull what you touch.
        • LEECH666
          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
          by LEECH666
          Good day ladies and gentleman!
          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
          01-19-2024, 05:46 PM
          by momaka
          03-15-2023, 10:17 PM
        • RetroComputingGrotto
          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
          by RetroComputingGrotto
          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
          I've uploaded a video of it happening on YouTube:
          I've taken the monitor...
          01-11-2024, 05:37 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • MOSSEP
          Monitor Audio RSW12 - Green light, but no sound
          by MOSSEP
          Hi
          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
          I have already tried replacing all of the...
          01-26-2025, 08:33 AM
