Dell U2312HM Why are these capacitors different colors?
  • FluxCap123
    • Nov 2021
    • 3
    I have a Dell U2312HM monitor with a bad power regulator. As part of the repair I was going to replace the capacitors near the regulator. All 4 capacitors are the same size/voltage but two are brown and two are black (see attached photos). The reference numbers on the two different capacitors are: 1301(M) and 1321(M). Does anyone know what they mean? Can I use the same replacement capacitors for all four?
    Any advice would be appreciated. Thanks.
  • lotas
    • Jan 2016
    • 4865
    • Russia
    Re: Dell U2312HM Why are these capacitors different colors?
    1301 (M) and 1321 (M) are production date 13 years 01 and 21 weeks.
    • Griffmadár
      • Nov 2021
      • 5
      • Hungary
      Hello.
      Yes, better to use the same for all. I have used the following for replacement in my Dell U2413
      https://industrial.panasonic.com/ww/...ls/EEUFR1C101B
      • FluxCap123
        • Nov 2021
        • 3
        Thanks for the information. I have ordered the parts.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
        • dell_sadness
          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
          by dell_sadness
          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
          Have extracted the BIN and want to know how to rebuild a clean BIOS
          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
          11-12-2025, 02:54 PM
