Dell U2312HM Why are these capacitors different colors?
  • FluxCap123
    • Nov 2021
    I have a Dell U2312HM monitor with a bad power regulator. As part of the repair I was going to replace the capacitors near the regulator. All 4 capacitors are the same size/voltage but two are brown and two are black (see attached photos). The reference numbers on the two different capacitors are: 1301(M) and 1321(M). Does anyone know what they mean? Can I use the same replacement capacitors for all four?
    Any advice would be appreciated. Thanks.
  • lotas
    • Jan 2016
    • 4717
    • Russia
    Re: Dell U2312HM Why are these capacitors different colors?
    1301 (M) and 1321 (M) are production date 13 years 01 and 21 weeks.
    • Griffmadár
      • Nov 2021
      • 5
      • Hungary
      Hello.
      Yes, better to use the same for all. I have used the following for replacement in my Dell U2413
      https://industrial.panasonic.com/ww/...ls/EEUFR1C101B
      • FluxCap123
        • Nov 2021
        Thanks for the information. I have ordered the parts.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
        • diamon
          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
          by diamon
          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
          Pictures of these boards:
          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
          Dell...
          02-28-2024, 12:51 PM
