Dell 1707FP no power
  • bob12345
    • Apr 2010
    • 31
    Re: Dell 1707FP no power
    We may have a winner!!! What is the part number for U404 (three pin device to the left of the gm5621-LF).
    PlainBill
    If my eyes aren't play tricks on me, the part# is DF64
    • bob12345
      • Apr 2010
      • 31
      A better pic - Is that device a voltage regulator of some sort?
      • PlainBill
        • Feb 2009
        • 7034
        If I'm correct, it's a reset controller. A quick background: Processors often have internal charge pumps, etc that require a finite time to stabilize after the chip receives power. Plus of course, the power supplies themselves require time to stabilize. The common way to do this was with a resistor/capacitor network holding the processor in reset until the cap charged. The problem is the timing was not consistent, and the relatively slow rise time of the reset line would cause problems. It also doesn't reset quickly in case of a power glitch. Thus the reset controller. That busy little circuit holds a comparator, an oscillator, a counter, and a driver. When the power comes on the driver holds the processor in reset. Once the comparator senses the supply is above a preset level (90% of nominal supply voltage, it allows the oscillator to drive the counter. Once the desired delay has been reached, the driver releases the reset and the processor starts.
        Measure the voltage on the three pins of U404. Also, there are three voltage regulators to investigate. Measure the voltage on all three pins of U601, U602, and U902.
        PlainBill
        • bob12345
          • Apr 2010
          • 31
          PlainBill
          Thanks for the info PB,
          As for the voltages:
          I've measured them relative to each pin (probes across pin 1 - 2 for example) on the 4 components - pins as per the attached image.
          U404:
          Pin 1 - 2 = 0V
          Pin 1 - 3 = 1.24V
          Pin 2 - 3 = 1.24V
          Voltages between pins 1-3 and 2-3 on the U404 seems to start at 1.24 then drop off to 0, bit unstable but perhaps showing the operation as you described.
          U601:
          Pin 1 - 2 = 5.2V
          Pin 1 - 3 = 1.24V
          Pin 2 - 3 = 3.96V
          U902:
          Pin 1 - 4 = 0V
          Pin 2 - 4 = 0V
          Pin 3 - 4 = 0V
          Pin 1 - 2 = 0V
          Pin 1 - 3 = 0V
          Pin 2 - 3 = 0V
          U602:
          Pin 1 - 4 = 0.4V
          Pin 2 - 4 = 0V
          Pin 3 - 4 = 0.84V
          Pin 1 - 2 = 0.4V
          Pin 1 - 3 = 1.24V
          Pin 2 - 3 = 0.84V
          The middle pin of the cluster of 3 (between pins 1 and 2) on the U602 doesn't seem to be connected to the board - i assume this is connected as pin 3.
          • PlainBill
            • Feb 2009
            • 7034
            U404:
            Pin 1 - 2 = 0V
            Pin 1 - 3 = 1.24V
            Pin 2 - 3 = 1.24V
            U601:
            Pin 1 - 2 = 5.2V
            Pin 1 - 3 = 1.24V
            Pin 2 - 3 = 3.96V
            U902:
            Pin 1 - 4 = 0V
            Pin 2 - 4 = 0V
            Pin 3 - 4 = 0V
            Pin 1 - 2 = 0V
            Pin 1 - 3 = 0V
            Pin 2 - 3 = 0V
            U602:
            Pin 1 - 4 = 0.4V
            Pin 2 - 4 = 0V
            Pin 3 - 4 = 0.84V
            Pin 1 - 2 = 0.4V
            Pin 1 - 3 = 1.24V
            Pin 2 - 3 = 0.84V
            Ohhh, my head hurts. These numbers aren't making sense to me. OK, let's try to make some sense of what is going on here. In the upper left corner of the board is a mounting hole, which seems to be designed to contact the metal mounting screws. That SHOULD be ground. Verify by measuring the resistance to the - lead on several of the caps, please. (This should be low - under 1 ohm).
            Set the meter on DC volts, and with the power on measure the voltage from ground to the pins of U404, U601, U602, and U901. ALSO list the part numbers of U601, U602, and U902, please.
            PlainBill
            • bob12345
              • Apr 2010
              • 31
              #26
              PlainBill
              So to verify I checked the mounting hole at the top left, resistance is low, as you said around 0.5-1ohm, the voltage relative to the negative cap terminals was indeed 0 so confirmed that as GND reference.
              So measurements relative to GND at the respective pins (layout as before):
              U404:
              Pin 1: 0V
              Pin 2: 0V
              Pin 3: 1.24V
              U601:
              Pin 1: 0V
              Pin 2: 5.21V
              Pin 3: 1.24V
              U902:
              Pin 1: 0V
              Pin 2: 0V
              Pin 3: 0V
              Pin 4: 0V
              U602:
              Pin 1: 0V
              Pin 2: 0.4V
              Pin 3: 1.24V
              Pin 4: 0.4V
              Part numbers of components (as read from top to bottom on each device):
              U601:
              A1
              AS117R-33
              B0606
              U902:
              LD117A
              L33ATB
              U602:
              A1
              AS1117L-18
              B0548
              • PlainBill
                • Feb 2009
                • 7034
                U404:
                Pin 1: 0V
                Pin 2: 0V
                Pin 3: 1.24V
                U601:
                Pin 1: 0V
                Pin 2: 5.21V
                Pin 3: 1.24V
                U902:
                Pin 1: 0V
                Pin 2: 0V
                Pin 3: 0V
                Pin 4: 0V
                U602:
                Pin 1: 0V
                Pin 2: 0.4V
                Pin 3: 1.24V
                Pin 4: 0.4V
                U601:
                A1
                AS117R-33
                B0606
                U902:
                LD117A
                L33ATB
                U602:
                A1
                AS1117L-18
                B0548
                Bingo!!! U 601 is a 3.3 volt regulator; it's output is 1.24V; U602 is a 1.8 volt regulator; it's output is .4 volts and it's getting it's input from U601. With those voltages the processor won't run. I'm not sure about U902; I think it provides power for the panel.
                PlainBill
                • bob12345
                  • Apr 2010
                  • 31
                  #28
                  PlainBill
                  PB do you suggest replacing all those parts? Ie the U404, U601, U602 and U902? Its strange there is no voltage across the U902 - a result of the other faulty components down the line?
                  • bob12345
                    • Apr 2010
                    • 31
                    #29
                    I'm in fact having trouble even trying to find datasheets from the part number of these components!
                    • PlainBill
                      • Feb 2009
                      • 7034
                      There are some errors in your list. Not surprising, considering the size of the IC, and the propensity to conserve space by omitting characters.
                      The AS1117R-33 is here.
                      For the AS117L-18, use the same datasheet, it's probably from a different vendor.
                      The LD1117A again is a similar part. It may again be a 3.3 v part, or it may be an adjustable regulator.
                      The next step requires finesse. Starting with the AS1117R-33 I'd remove the part and test it with 5V in, and a 25 ohm load. If the output was wrong, I'd replace the part with a new one. If the output was right, I'd try to determine why the output was overloaded, perhaps by removing the AS117L-18.
                      We've been seeing a number of these recently, but with the output voltage too high. That usually kills the processor or it's support chips.
                      PlainBill
                      • bob12345
                        • Apr 2010
                        • 31
                        #31
                        PlainBill
                        I'll try and tackle the removal and testing of those parts as you mentioned during the week. In the mean time I think I'll order some replacements for the above. I'm assuming as the original parts are likely to be tricky if not near impossible to get hold of, compatible ones of the same rating (voltage), current output, package type, basically the same or better than the specs in the datasheet would do the job? Do you think its worth replacing that U404 considering the details of its part number are pretty poor (DF64?).
                        Also the LD1117A - is this likely to be a similar datasheet
                        Once again PB, thanks for all your help, very much appreciated!
                        • PlainBill
                          • Feb 2009
                          • 7034
                          The two voltage regulators are 'jelly bean' parts - available from a number of ventors; sometimes with different part numbers, all serving the same function. The ST datasheet is for the equivalent part from a different vendor. The ST parts have a higher current rating.
                          That DOES bring up an interesting point. Why weren't you able to detect an input voltage for U902? If that is a 3.3V regulator, it must be fed from the 5V supply. Doh!! Maybe it's switched off until commended on by the processor?
                          I also wouldn't consider doing anything with U404. Again, it appears it isn't receiving the proper voltage, so it's inactive.
                          PlainBill
                          • bob12345
                            • Apr 2010
                            • 31
                            #33
                            PlainBill
                            Yeah its strange there was no voltage on the U902, i checked it a couple of times when I tested. Does this mean a possible processor fault - ie the processor not telling it to turn on as you mentioned?
                            • PlainBill
                              • Feb 2009
                              • 7034
                              I think that's what is happening. After all, the panel itself takes a fair amount of power. Why not reduce the energy consumption by turning off the power to the panel at the same time you turn off the inverters.
                              PlainBill
                              • bob12345
                                • Apr 2010
                                • 31
                                #35
                                Before ordering these parts, based on the output voltages being under, can I assume that the processor is ok? (i know that both under voltages and over can damaged an IC but under is surely better than over?). Cause if the processor is damaged then I guess its probably economical to just find a replacement board.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Assumptions are dangerous. However, yes, if I had determined that the voltage regulator was defective, outputting too low a voltage I wouldn't hesitate to order a replacement part. Knowing what I know now, I would hesitate to replace one that had output too high a voltage.
                                  PlainBill
                                  • bob12345
                                    • Apr 2010
                                    • 31
                                    #37
                                    Thanks Bill, I'll order up a load of voltage regulators whilst I try and figure out my other broken monitor! I wish I got the easy and obvious problems like bulging caps - oh well such as life but I guess I've learnt a load so far!
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Well, a couple of weeks ago I picked up three monitors; a 'dead' Dell 17", a 19" Samsung, and a 22" Proview. Both the Proview and Samsung had symptoms that indicated bad caps. Open them up and found a bunch of cheap bulging caps. Put together a list, and one of the caps for the Samsung is out of stock.
                                      Now I take a look at the Dell. It's got the power supply, inverter, and video circuitry on one board. No power LED, but the power supply is good. All the regulators for the video circuitry check out; all the caps check out with the ESR tester. Drag out the scope and the crystal is working. Check the wires to the front panel, all buttons are feeding signal back to the main board.
                                      There are only three ICs in the video section; a gm 2621LF, a 24C02WI, and a Pm25LV010. The first is the video processor/ control chip. The second is the serial EEPROM, the third apparently holds the firmware (I can't find datasheets on the gm2621-LF). About all I can do at this point is to check to see if serial data is passed to the two serial chips. Then I can order parts.
                                      PlainBill
                                      • terry
                                        • Oct 2007
                                        • 91
                                        • Milton Keynes, Bucks
                                        #39
                                        Hi, I just got a monitor with the same problem, I have checked the voltages and are the same.
                                        U404:
                                        Pin 1: 0V
                                        Pin 2: 0V
                                        Pin 3: 1.24V
                                        U601:
                                        Pin 1: 0V
                                        Pin 2: 5.21V
                                        Pin 3: 1.24V
                                        U902:
                                        Pin 1: 0V
                                        Pin 2: 0V
                                        Pin 3: 0V
                                        Pin 4: 0V
                                        U602:
                                        Pin 1: 0V
                                        Pin 2: 0.4V
                                        Pin 3: 1.24V
                                        Pin 4: 0.4V
                                        Did you get your one working, what parts did you replace.
                                        Terry
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          <SNIP>
                                          Terry
                                          I did try a blank 'user settings' serial eeprom without any success.
                                          In another thread Per Hansoon had a similar problem which he resolved by reloading the IC containing program memory. Note that this requires removing the chip from the board and using the appropriate programmer to program it. It also requires a source of the firmware. He found his on a Russian site.
                                          In the past few days I've learned (from a thread here) that one of the LCD repair stores is selling proms preloaded with firmware (but nothing compatible with these monitors) for a very reasonable price (under $5.00).
                                          Given the difficulty Per had building an adapter (he mentioned wires and duct tape), that bears further research.
                                          PlainBill
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display β€” it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! πŸš€
                                            I have no idea what I’m doing, but I’m learning by trial and error.
                                            I’m currently working on a Dell Optiplex AIO 7490β€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
                                          • zlr8r
                                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                            by zlr8r
                                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                            Ill try and give as much info as I can.
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                            Then it started getting weirder!
                                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                            12-12-2023, 09:31 PM
