Dell 1707FP no power
  • bob12345
    • Apr 2010
    • 31
    I have a Dell 1707FP which when connected to mains power shows no sign of life - no power light nothing and no response when pressing the buttons. I have taken the monitor apart and there appears to be no blown or damaged capacitors. Does anyone have any ideas as to what could be wrong with it? I have tested the LCD panel itself with another monitor and that works fine.
  • pedro
    • 199
    • AUSTRALIA
    Re: Dell 1707FP no power
    There's no rampant signs of cap failure to me in the pics or the symptoms.
    First - power OFF - check the red fuse to the left of the AC inlet for continuity, then if that passes measure (carefully) - power ON - the voltage across the large 450V cap to the right
    Friends don't let friends buy Samsung ....
    • bob12345
      • Apr 2010
      • 31
      I've measured the resistance across the red fuse (T 5A 250V) with power off, on the lowest resistance setting on the digital multi meter (200ohm setting) I get a reading of 0.4 which to me sounds like a good fuse? (low resistance but not open circuit). The highest setting on the DMM (2000Kohm) shows 0 probably as the fuse is low resistance (i assume - correct me if i'm wrong).
      When testing the 450V cap, do I need to connect the rest of the parts, ie the logic board, inverters, LCD etc? or can I just plug in the AC to the board as pictured? I also assume that the DMM will need to be set to AC as this cap is on the AC side? Thanks
      • pedro
        • 199
        • AUSTRALIA
        Yes, continuity is there.
        Just in case there is a glitch, reconnect to the proper configuration then test.
        • bob12345
          • Apr 2010
          • 31
          Ok I hooked up all the components, testing the voltage across the 450V blue large cap, (DMM set to AC - 600V scale) I measured 735V AC and (DMM set to DC - 600V scale) 330V DC. I did notice the first time I took the measurements there was a ticking noise coming from somewhere on the board. This was not apparent when I unplugged - reconnected mains for the second retest. - I've on EU power so 220v-240v ac.
          • bob12345
            • Apr 2010
            • 31
            Just to add, I'm assuming that this AC measurement is peak to peak so half waveform would be 367.5V AC or this capacitor is connected to the DC side behind a rectifier? or else this 450V rated cap would be up in flames!
            • PlainBill
              • Feb 2009
              • 7034
              Ticking sound?? Replace C857.
              PlainBill
              • bob12345
                • Apr 2010
                • 31
                Its strange it doesn't seem to make the ticking noise any more - but I can hear a constant faint static noise and C857 looks from the outside OK, do you reckon it will solve the problem?
                • PlainBill
                  • Feb 2009
                  • 7034
                  Sarcasm mode ON. No, I don't think it will fix the problem. I just want you to replace if so you will be unhappy and I will look like an idiot! Sarcasm mode OFF.
                  Perhaps I got ahead of myself. Have you checked the outputs of the power supply? Understand, the power LED is controlled by the processor on the 'logic card' (I've got to start using a better name for that). Just because the power LED is off doesn't mean the power supply is dead.
                  If you do not have any output voltage, yes, replace that cap. It provides the power for the SMPS controller during the power supply startup. If it fails (and it won't show any signs when it does), the result will be a ticking sound and a dead power supply.
                  PlainBill
                  • mathog
                    • Mar 2010
                    • 2655
                    Since there do not seem to be speakers in this model I'm curious as to which part of the circuit makes the noise. Specifically, what component ticks, and why?
                    Thanks.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Thanks.
                      Usually the SMPS transformer. The capacitor has enough energy stored to drive the power FET at least once, and that drives a 166V pulse into the SMPS transformer. Since the filter caps are discharged, the secondaries are driving into a very low resistance; a lot of energy is transferred. In normal operation each subsequent pulse would charge the filter caps, so much less power would be transferred (and the pulses would be at ultrasonic frequencies). Because the start-up cap is bad, it discharges quickly, before the tertiary winding that supplies the SMPS with run power can charge the capacitor.
                      Look at this thread for more information.
                      PlainBill
                      • bob12345
                        • Apr 2010
                        • 31
                        PlainBill
                        In terms of the output, i assume you mean the connection between the power board and the "logic board"? I see that there is one red wire and the other 9 black. I assume not all are power but some also signal cables?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Yes. Sometimes there is a legend on the top or bottom of the board. Another approach is (with the power supply fastened in place) to measure the voltage from ground to each of the pins in the cable.
                          PlainBill
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            PlainBill
                            I agree. The little guy is sometimes responsible for either the no-startup tick or the 5v line bouncing like crazy.
                            • ASUS ROG Maximus IX Code
                            • Intel Core i5-7600K 3.8GHz
                            • Windows 10 Pro x64
                            • GeForce GT1050
                            • pedro
                              • 199
                              • AUSTRALIA
                              Thanks.
                              Google magnetostriction
                              • bob12345
                                • Apr 2010
                                • 31
                                PlainBill
                                I've measured the voltage from ground (or what I think is ground - please correct me if i'm mistaken) - the three pins on the right of the (pins 0 - 2) connector CN853 (PSU -> Logic card) which appear to be connected to the ground track of some nearby caps and that track also goes to the chassis mounting screw hole so I assume thats a suitable ground location (see attached underside pic). The voltages relative to these GND pins (right to left as shown on underside pic):
                                Pins 0-2: GND (0V)
                                Pin 3: 0V ---- (as expected as this appears to be connected to the 12V optional speaker attachement - not attached)
                                Pin 4: 5.18V
                                Pins 5-7: 5.21V
                                Pins 8-9: 0V ---- (appear to go to one of the inverter transformers T2?)
                                All parts where connected: LCD panel, inverters, logic board (but not the usb header board)
                                No ticking noise heard now, only the constant buzz/humm of something.
                                Thanks for all your help so far!
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Pins 0-2: GND (0V)
                                  Pin 4: 5.18V
                                  Pins 5-7: 5.21V
                                  One thing is apparent; another can be inferred.
                                  1. The power supply is working.
                                  2. You have very good ears.
                                  As I've said repeatedly, the power LED is controlled by the processor on the logic card. It's time to post pictures of the logic card and see if we can find the problem.
                                  PlainBill
                                  • bob12345
                                    • Apr 2010
                                    • 31
                                    PlainBill
                                    I'm dreading that the logic board is dead, probably hardest to source/repair i'm assuming! Here are two pictures of either side of the logic board (model is a 1707FPt). Nothing appears to be burnt out visually.
                                    Sorry about the blur in the second pic, camera doesn't like to focus with no flash in macro mode.
                                    • bob12345
                                      • Apr 2010
                                      • 31
                                      My mistake the monitor is a 1707FPf not t.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        We may have a winner!!! What is the part number for U404 (three pin device to the left of the gm5621-LF).
                                        PlainBill
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • Mark01
                                          Dell Optiplex 7490 AIO - red power led after flash
                                          by Mark01
                                          Hi guys,
                                          This is my first post! 🚀
                                          I have no idea what I’m doing, but I’m learning by trial and error.
                                          I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                          07-04-2025, 12:54 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
