Acer V193w has odd backlight problem
  • questionmark425
    • Mar 2010
    • 7
    I have an Acer V193w with an odd backlight issue. At first I thought it was 2 seconds to black, but now I'm not so sure.
    The monitor originally went 2 seconds to black on me, but after playing with it, it will stay on for an undetermined amount of time (from 2 seconds, all the way up to a couple of hours) and then the monitor (not just the backlight) will turn off (power light still on and blue).
    But if I launch a game, the monitor will instantly shut off.
    The power and logic board look all brand new and shiny. I bought caps for the power board, just haven't installed them yet.
    Let me know if you want pictures of the boards, and I will disassemble the monitor again (this monitor was, oddly, extremely easy to take apart).
  • 396ss
    • Oct 2008
    Re: Acer V193w has odd backlight problem
    I know this thread is nearly a year old, but did you ever figure out the odd backlight problem? I am experiencing the same exact issue once I launch a game.
    I dissembled the monitor and everything looked decent. For good measure I replaced some of the cheaper samxon and suscon caps and it still experienced the same issue.
    • alexanna
      • Mar 2010
      • 1346
      Some pictures sure would help, as the old saying goes please use managed attachments.
      This is just a guess maybe a game puts a little more demand on the LCD panel, By having to change colors rapidly, or refresh the screen.
      I think you should verify you have good outputs of the voltage regulators on the logic board, I have found sometimes they will start out good and then slowly drop out to a lower voltage. You may have to monitor these for a while.
      One question if you disconnect the cable from the logic board to the lcd panel ,What happens do the back lights stay on?
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
      • grbo92
        Backlight problem Acer LA-031P
        by grbo92
        i have one acer Nitro 5 without backlight on my desk.
        Mainboard model: LA-L031P GH53Z REV 1B
        Attached schematics and boardview are REV 1A, slightly different as REV 1B.
        11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
        Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
        Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
        09-09-2024, 03:49 AM
      • tmhobadcap
        LG 24MP56HQ-P Monitor Backlight problem?
        by tmhobadcap
        I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
        Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
        I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
        10-13-2021, 01:52 PM
      • tmhobadcap
        by tmhobadcap
        10-12-2021, 01:43 PM
      • Zilicon
        NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
        by Zilicon
        Greetings everyone.
        Please I need help with the above monitor.
        Below is the summary of what happened and what I have done:
        The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
        The backlight driver IC is 0b3350cp.
        I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
        11-07-2023, 09:12 AM
