Dell E171FP No power
  • Welchs101
    • Sep 2008
    • 979
    I am working on a Dell E171FP. Prior to this post i had posted a few earlier comments on this repair at this bad-caps forum link.
    https://www.badcaps.net/forum/showthread.php?t=8951
    I received the replacement parts yesterday and i put them in. I put in the new bridge rectifier, two new fuses, and a replacement thermistor SCK 103.
    Note: I had to "drill" the holes for the bridge rectifier slightly bigger for the leads to fit in.
    I put all the parts in with the board not connected to lamps or screen.....just the board on the table. I powered it up............did not hear any popping of the fuses so i thought this was a good sign.
    I measured across the "Big" filter cap and i get about 170V DC.
    Not sure what to measure next? Anyone have any ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E171FP No power
    Measure the outputs of the supply (probably 5 VDC and 12VDC). If there is no output check all the diodes to the left of the transformer and near the heat sink. If those are good, replace C6, C8, and the cap to the right of the lower heat sink.
    PlainBill
    • Welchs101
      • Sep 2008
      • 979
      Ok....I am enclosing a pic ture of the main board with one of the parts surrounded by a red box. Is this the part you want me to measure outputs on?
      I looked up this part (i also took a side view picture of part). The markings are "DP502T". I could not find this part but i did find a web address that mentioned this part.
      http://www.electronicspoint.com/sync...es-t64642.html
      In this web address they say this is a fairchild part similar to this "KA5Q12656RTYDTU ". I found this part on mouser and the datasheet is here
      From the data sheet:
      Pin1=Drain
      Pin2=Gnd
      Pin3=Vcc
      Pin4=FB (not sure what these are)
      Pin5=Sync (not sure what these are)
      I measured the following:
      Pin1=166.8V DC
      Pin2=did not measure....used this as a gnd to measure other voltages
      Pin3=11.46V DC
      Pin4=0.63V DC
      Pin5=4.96V DC
      What is this device? Are the voltages i measured ........what they should be? Hard to tell from datasheet.
      • Krankshaft
        • Jan 2007
        • 2328
        That is not just a FET but it is also the PWM IC.
        It is a switching FET, PWM, and protection on one chip that's why it has 5 leads. So it seems that Topswitch isn't the only manufacturer making these anymore.
        Manufacturers use these compact switcher ICs to reduce the part count. All the better because it simplifies the troubleshooting process.
        Measure the secondary voltages as Plainbill said if you get nothing.
        If the bridge rectifier died then there's a chance the PWM section of the chip got zapped through the VCC pin. Sometimes fuses just aren't fast enough to stop semiconductor damage.
        • Welchs101
          • Sep 2008
          • 979
          What exactly are the secondary voltages? Just want to make sure i measure what it is your asking for.
          Can i assume the DP502T is operating correctly?
          Thanks again for your help.
          • Krankshaft
            • Jan 2007
            • 2328
            When the PSU is plugged in measure for DC on the filter caps off the rectifiers the two packages on that heatsink.
            Not sure how many rails this PSU has maybe one 12V and one 5V.
            But in the past I've seen cheap Chinamart PSUs parallel output rectifiers to get more output current. So without a look at the board it could be just one 12V rail.
            You can't assume anything about the PWM/FET until you check the outputs.
            If the output voltage is low it's a feedback problem if the voltage is non existent it could be the IC/FET or an issue in the startup circuit like a startup cap or resistor.
            Whenever you have a blown fuse
            • Welchs101
              • Sep 2008
              • 979
              I already measured DC voltage across the big filter cap......~ 170V DC.
              As far as the "two packages on the heat sink" are you talking about the parts i have drawn a box around (see enclosed pic). ARe these the devices you wanted me to measure?
              Also, i did measure the DC voltages on the PWM
              Pin1=166.8V DC
              Pin3=11.46V DC
              Pin4=0.63V DC
              Pin5=4.96V DC
              • PlainBill
                • Feb 2009
                • 7034
                !!!! There are two ways to solve this.
                1. Measure the voltages across the caps on the right side of the board - the six caps in a group. You should get two sets of voltages - one about 5 volts, the other probably about 12 volts.
                2. Measure the voltages on the cable linking the power supply to the logic card.
                The power LED is controlled by processors on the logic card. I spent too many hours assisting people who thought they had a power supply problem when it was actually a reset controller problem.
                PlainBill
                • Welchs101
                  • Sep 2008
                  • 979
                  (See enclosed pic as a reference)
                  Voltage across caps:
                  DC Volts across 1000uF/25V caps: Voltage same across all 3. With red probe on + and black probe on -. I measured 7.71V DC
                  DC Volts across 2200uF/10V and 470uF/25Vcaps: Voltage same across all 3. With red probe on + and black probe on -. I measured 4.411V DC
                  I also measured the voltages at the connector between powersupply board and logic board (see pic for reference):
                  At 1: 4.11V DC
                  At 2: 3.18V DC
                  At 3: 0V DC
                  At 4: 0V DC
                  At 5: 0V DC
                  At 6: 0V DC
                  At 7(Blue): 7.71V DC
                  • Welchs101
                    • Sep 2008
                    • 979
                    I think the 7.71 is kinda low.
                    Any ideas?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      At 1: 4.11V DC
                      At 2: 3.18V DC
                      At 3: 0V DC
                      At 4: 0V DC
                      At 5: 0V DC
                      At 6: 0V DC
                      You're right, 7.71 is very low. Also, 4.11 is slightly low. That points to an excessive load somewhere. Does the inverter connect to the logic card?
                      PlainBill
                      • Welchs101
                        • Sep 2008
                        • 979
                        Yes, it does. How did you know that? I have included a picture for reference.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          I'm smarter than I look.
                          If you took those voltage readings with the inverter hooked up, try disconnecting it and see if they improve.
                          PlainBill
                          • Welchs101
                            • Sep 2008
                            • 979
                            I disconnected the main board from the power supply. This means the power supply is not connected to either the inverter board or the logic board.
                            DC Volts across 1000uF/25V caps: Voltage same across all 3. With red probe on + and black probe on -. I measured 12.2V DC (was 7.71)
                            DC Volts across 2200uF/10V and 470uF/25Vcaps: Voltage same across all 3. With red probe on + and black probe on -. I measured 4.98V DC (was 4.11)
                            At 1: 4.98V DC (was 4.11)
                            At 2: 0.034V DC (was 3.18)
                            At 3: 0V DC (was 0)
                            At 4: 0V DC (was 0)
                            At 5: 0V DC (was 0)
                            At 6: 12.2V DC (was 0)
                            At 7(Blue): 12.2V DC (was 7.71)
                            What does this mean? Does this mean the power supply board is ok and there is something wrong on either the main or inverter board?
                            • PlainBill
                              • Feb 2009
                              • 7034
                              At 3: 0V DC (was 0)
                              At 4: 0V DC (was 0)
                              At 5: 0V DC (was 0)
                              First of all, there are no absolutes with the limited test you just did. A more refined test would involve putting a 2 ohm power resistor across the 5V output and testing the power supply at full load. But the odds are that the power supply is fine, so let's go with that.
                              The next test would be to hook the logic card back up to the power supply, but leave the inverter disconnected. Then repeat measuring the voltage. There is no need to measure the voltage at the caps, measuring at the connector is fine. If the voltages are still 5V and 12V it improves the odds that the problem is in the inverter (Case A). If it drops again, then it is either the power supply or the logic card (Case B).
                              In Case A, hook the inverter back up and carefully feel for any point that is getting unusually warm. I'm guessing that the bad part is dissipating something in the order of 5 watts.
                              In Case B, it is not necessary to hook the inverter up, just check the logic card for any part that is getting very hot.
                              Do this fairly quickly; don't leave the power supply on for more than a minute when the 12V output is down around 7 volts.
                              PlainBill
                              • Welchs101
                                • Sep 2008
                                • 979
                                ok. With logic board connected and Inverter NOT connected i measure the following:Voltage across caps:
                                I measured the voltages at the connector between powersupply board and logic board (see pic for reference):
                                At 1: 4.11V DC
                                At 2: 3.18V DC
                                At 3: 0V DC
                                At 4: 0V DC
                                At 5: 0V DC
                                At 6: 0V DC
                                I will not try and find the part that is getting hot. Will post what i find in just a min.
                                • Welchs101
                                  • Sep 2008
                                  • 979
                                  ok. With power supply and main board connected (no inverter connected) I touched around the logic board and i could not find anything "hot".
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Darn!! Maybe it is the power supply. One more thing to check: What is the voltage at pins 3 and 4 of the 'power switch' (the 5 pin device you measured in post 7) with the logic card disconnected and with it connected?
                                    PlainBill
                                    • Welchs101
                                      • Sep 2008
                                      • 979
                                      Bill,
                                      I measured the following (using the black probe set to the AC ground. Gnd coming from AC plug)
                                      With logic board connected:
                                      Pin1: -81.5V DC
                                      Pin2: -81.4
                                      Pin3: -70.6
                                      Pin4: -81.6
                                      Pin5: -76.5
                                      With logic board DIS-connected:
                                      Pin1: -81.0V DC
                                      Pin2: -81.7
                                      Pin3: -64
                                      Pin4: -81.3
                                      Pin5: -76.5
                                      Did i use the right gnd.........or such i use pin2 (gnd) measure relative voltages. Recall that according to this
                                      pin 2 should be gnd.
                                      • Welchs101
                                        • Sep 2008
                                        • 979
                                        I measured the voltages again this time using the gnd pin from the device to measure relative voltage levels.
                                        Note: Inverter board is not connected for any of the measurements. Same as in previous post.
                                        Pin1: 167.8V DC
                                        Pin2:
                                        Pin3: 11.45
                                        Pin4: 0.061
                                        Pin5: 4.96
                                        With logic board NOT connected:
                                        Pin1: 168V DC
                                        Pin2:
                                        Pin3: 18.24
                                        Pin4: 0.331
                                        Pin5: 4.96
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Steph.hen
                                          Bridge rectifier identification part number KPB305G
                                          by Steph.hen
                                          Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                          I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                          08-29-2024, 09:52 AM
                                        • mpn78
                                          Fujitsu Q556, What capacitor for bridge rectifier?
                                          by mpn78
                                          Hello
                                          My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                          There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                          Thanks....
                                          04-05-2022, 12:31 PM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • EasyGoing1
                                          Reading input and output of bridge rectifier on the same scope?
                                          by EasyGoing1
                                          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                          06-26-2022, 12:52 AM
