WestingHouse L2210NW Will not power.
    Re: WestingHouse L2210NW Will not power.
    measurements from the transformer on the top left with the black line on it. everything was tested on 2k ohms
    black probe on pin 1, red on pin 2 - .872 ohms
    black probe on pin 1, red on pin 3 - 1. out of range
    black probe on pin 1, red on pin 4 - 1. out of range
    black probe on pin 1, red on pin 5 - 1. out of range
    black probe on pin 1, red on pin 6 - 1. out of range
    black probe on pin 1, red on pin 7 - 1. out of range
    black on pin 1, red on pin 8 - 1. out of range
    black probe on pin 2, red on pin 3 - 1. out of range
    black probe on pin 2, red on pin 4 - 1. out of range
    black probe on pin 2, red on pin 5 - 1. out of range
    black probe on pin 2, red on pin 6 - 1. out of range
    black probe on pin 2, red on pin 7 - 1. out of range
    black probe on pin 2, red on pin 8 - 1. out of range
    black probe on pin 3, red on pin 4 - .001 ohms
    black probe on pin 3, red on pin 5 - .001 ohms
    black probe on pin 3, red on pin 6 - .001 ohms
    black probe on pin 3, red on pin 7 - 1. out of range
    black probe on pin 3, red on pin 8 - 1. out of range
    black probe on pin 4, red on pin 5 - .001 ohms
    black probe on pin 4, red on pin 6 - .001 ohms
    black probe on pin 4, red on pin 7 - 1. out of range
    black probe on pin 4, red on pin 8 - 1. out of range
    black probe on pin 5, red on pin 6 - .001 ohms
    black probe on pin 5, red on pin 7 - 1. out of range
    black probe on pin 6, red on pin 7 - 1. out of range
    black probe on pin 6, red on pin 8 - 1. out of range
    black probe on pin 7, red on pin 8 - justs around from 1.121 to 1.580 ohms
    black probe on pin last-1, red on pin last - 1. out of range
      Hmm, without a spec sheet or another transformer to compare to, I'm not sure if the 2 readings above are correct or not.
      Do you have another monitor where you can do the CCFL test?
      --- begin sig file ---
      --- end sig file ---
        now i was reading the other things that could be bad and i tested what i think is a fuse (F301) also circled on the attached picture.
        i tested it at 2k ohms and got a reading of .004
        i also tested it with 200 setting and got .8
          I just realized that no one including myself asked if you can still see the video/image if you shine a flashlight on the screen? Please answer.
            would any monitor work or does it have to be the same one? cus i have a 17 inch hp monitor just saying around
              also there is another transformer on the board as well should i get the readings from that one as well?
                It is best to get the same because I'm not sure how a 17 inch length CCFL tube will react in a 22 inch monitor. If the connector, voltage, and current are the same, it shouldn't be a problem.
                  It is not the same transformer on the board. The one you measured is the transformer that drives the CCFLs.
                  Most inverter boards that I have seen have at least 2 transformers driving the CCFLs. Yours only has the 1.
                    What is the part number of that 4 legged chip next to c66 on the backside?
                      nikos
                      p2804nd5g
                      un45j0a84
                        p2804nd5g
                        Okay, we are going to make sure this FET isn't shorted. Set your mastech to 200 ohms (two hundred).
                        Refer to the attached diagram.
                        1) black on S1, red on D1 - record/report ohms
                        2) black on S1, red on G1 - record/report ohms
                        3) black on D1, red on G1 - record/report ohms
                        4) black on S2, red on D2 - record/report ohms
                        5) black on S2, red on G2 - record/report ohms
                        6) black on D2, red on G2 - record/report ohms
                          1) black on S1, red on D1 - 1 out of range
                          2) black on S1, red on G1 - 1 out of range
                          3) black on D1, red on G1 - 1 out of range
                          4) black on S2, red on D2 - 1 out of range
                          5) black on S2, red on G2 - 1 out of range
                          6) black on D2, red on G2 - 1 out of range
                            Since your mastech shows 0.7 ohms when the two probes together, it is a good fuse at 0.8 ohms.
                              FET looks good.
                                ok good to know thanks. and thanks for walking me through these trouble shooting steps. Does the FET look good?
                                  This video (about 8 minutes long)
                                  http://www.youtube.com/watch?v=eNuGWBPRGKA
                                  shows why I'm suspicious about the transformer readings.
                                  Are there any markings on the transformer other than the top?
                                    hmmm ok so then that leaves caps or CCLFs
                                      no just that crack on the top is the only things i can see
                                        Can you mark up the bottom side of the picture and tell me how you numbered the transformer pin tests?
                                          Hi here is a pdf of the board layouts and so on
                                          hope it helps
