I have a Gateway FPD1530 Flat Panel LCD Monitor. When turned on it lights up and you can see the picture perfectly for about 1 second then the screen go's dark. Flashlight test reveals the picture is still there, its just dark. Power light stays solid green. Pictures of the Logic Board are attached. I cant see any bad caps or dry solder joints. Any ideas will be greatly appreciated.
Gateway FPD1530 works for a second then dark
Tags: None
Re: Gateway FPD1530 works for a second then dark
Also, does anyone know of a device to test Capacitors in circuit? -
This is a classic description of the 'two seconds to black' symptom. I've marked up the top picture. Try measuring the AC voltage from point A to Gnd and from point B to Gnd while the backlights are on. Also check the inverter transformers for bad solder joints.Originally posted by freakytiki4uI have a Gateway FPD1530 Flat Panel LCD Monitor. When turned on it lights up and you can see the picture perfectly for about 1 second then the screen go's dark. Flashlight test reveals the picture is still there, its just dark. Power light stays solid green. Pictures of the Logic Board are attached. I cant see any bad caps or dry solder joints. Any ideas will be greatly appreciated.
By the way, this is a picture of the inverter / power supply, not the Logic Board. (Pictures of the right board, you just gave it the wrong name.)
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
A gets near 10 volts AC for a split second and B gets near 6 volts AC for a split second. I have to turn the monitor on and off to make that happen while holding meter leads to proper spots. I will resolder transformer joints just to be sure. Next Sir ?Comment
Resoldered joints on both small transformers, still does the same thing. Would bad caps cause this? They dont appear to be bad (not swollen).Comment
No, it's unlikely bad caps would cause this. You are measuring the voltage on the return line, which is proportional to the current. If you tried several times to read the voltage and got consistent results, the only conclusion I can come to is one CCFL is carrying more current than the other.Originally posted by freakytiki4uResoldered joints on both small transformers, still does the same thing. Would bad caps cause this? They dont appear to be bad (not swollen).
NOW, we have to figure out why. If you look at the top of the board near each of the connectors for the CCFLs you will see the transformers. If you look at the underside you will see the transformer pins are numbered 1-6 (primary side) and 7 & 8 on the secondary side. With power off, measure the resistance of each secondary.
How do I measure resistance? (I know, Im a doofus) I have a multimeter.Comment
(Well, as long as you know.) Disconnect the power supply / inverter board from the rest of the monitor turn it face down in the same position as the picture. Set the DMM to the 2K ohms range. In the lower left corner of the board you will see two points labeled 7 and 8, with the 8 above the 7. Put one probe on the pin labeled 7 and the other on the pin labeled 8. Write down the reading. Now look at the lower right corner of the board. You will see two more pins, but this time the 8 is to the left of the 7. Measure the resistance between the two points.Originally posted by freakytiki4uHow do I measure resistance? (I know, Im a doofus) I have a multimeter.
lol, my wife is usually first to admit Im a doofus and I runa close second.
ok, my MM only has 1K Ohm and 10 Ohm Setting so I used !k Ohm Setting.
I will post 4 pictures.
The 1st one shows my MM at rest.
The 2nd one show my MM with leads touching so you can see what it reads.
The 3rd shows the secondaries reading closest to the power plug.
The 4th shows the secondaries reading farthest away from the power plug.
I await your directions and Im sorry to be such a pain.Comment
Try it again on the X10ohm scale. That should give you a reading closer to mid scale. We are looking at what might be very small differences in resistance.Originally posted by freakytiki4ulol, my wife is usually first to admit Im a doofus and I runa close second.
By any chance is there enough slack in the wires so you can repeat the original test, but swapping wires to the opposite connectors?Originally posted by freakytiki4uok on the 10 Ohm scale I get a consistent reading on both secondaries of 60 ohms resistance. See attached Pic of reading
Do you mean test the secondaries by swapping the meter leads around? If so, Yes, and reversing the wires gives the same 60 Ohm result on each secondary.Comment
No, let me explain what I meant. Review posts 3 and 4. In those steps you measured the return voltages and discovered there was a difference between the two sides. The latest test indicates there is no difference between the secondaries of the two transformers. That presents a problem - ordinarily the next step would be to measure the output voltage of each transformer. However, that could easily fry your VOM (been there, done that with 5000 volts, didn't get a tee shirt, and don't want to see it done again). And we still have a problem. Is the 'B' return current lower because the 'B' transformer is not putting out high enough of a voltage, or because there is a problem with the 'B' CCFL or it's wiring OR because the 'A' CCFL is drawing too much current?Originally posted by freakytiki4uDo you mean test the secondaries by swapping the meter leads around? If so, Yes, and reversing the wires gives the same 60 Ohm result on each secondary.
The test I am proposing is to plug the 'A' CCFL into the 'B' socket, and the 'B' CCFL into the 'A' socket. If the return voltage at the 'A' socket is still higher, that tells us the problem lies in the inverter. If the 'B' voltage is now higher, that tells us the problem lies in the CCFLs and associated wiring.
Just repaire an Viewsonic Optiquest Q7 displaying same problem. Removed the inverter and none of the six caps were bulging. Checked all problems PlainBill suggested above and transistors. All good. The caps were Elite so they were suspect right away. Replaced 2, 220uf-25v with Nichicon same values RZ(M) series. Replaced 2, 680uf-16v with Nichicon 1000uf, 16v.(All i had) PB(M) series. Left the high voltage cap alone and a small 50v cap.
Put back together and has been burning in with a beatiful screen since 3pm EST. So, just cause caps aren't bulging does not mean they are not bad. Hope this helps...Comment
Are you referring to the two electrolytic caps?Originally posted by mcfischerI fixed many of these by replacing the 2 1Uf caps at the top edge of the board (between the bulb sockets)
Mike
For what it's worth, I'm trying to put together a systematic approach to the 'Two Seconds to black' problem. That is one cause I hadn't encountered yet.
Bill,
Yes the two electrolytics. I replace them with 2.2 uF just to feel better. Been doing this stuff a long time and I think it may help in the long run.
I have fixed more than 50 this past 2 years, same caps....
MikeComment
I also have this same monitor with the same problem. Which caps on which are you referring to mcfischer? Possible pics?Comment
How about this? You're the one with the monitor, you provide the picture of the inverter. If mcfischer isn't around to answer you, I'm pretty sure I can supply the identification.Originally posted by rokkaholikI also have this same monitor with the same problem. Which caps on which are you referring to mcfischer? Possible pics?
by DanstonaWas watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal... -
by Bazfletch3Hi all
While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
From there I envisaged that the backlighting wasn't working, however... -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... - Loading...
