How to determine ESR from datasheet for SAMXON 68UF/450v
  • Welchs101
    • Sep 2008
    • 979
    I measured the ESR value for a large 68uF cap....measured ~ 52 using a friends ESR meter which i need to give back.
    My friend said this was high but i was wondering what the ESR value should be.
    I am enclosing a pic of the cap.
    I cant seem to find datasheet or any info on the ESR for this cap. Can someone help?
  • PlainBill
    • Feb 2009
    • 7034
    Re: How to determine ESR from datasheet for SAMXON 68UF/450v
    The ESR for caps like those is usually not specified; they don't endure the high frequency surges the SPMS output caps do. HOWEVER, I believe you can find an approximate value. I just did a search on my favorite vendor and found the ESR speced on three equivalent (68uF, 450V) caps. It ranged from 2 ohms to 5 ohms. Seven other hits from the same search did not have their ESR listed.
    IMHO, your friend is correct; that value is very high.
    PlainBill
    • Welchs101
      • Sep 2008
      • 979
      Thanks. Thats exactly what i needed to know.
      If you still have the link to that spec i would like to take a look at it.
      Thanks again!!!!!!!!!!!!!!!!!!!!!!!!!!
      • PlainBill
        • Feb 2009
        • 7034
        Go to Digikey's site and do a search on 68uF, 450 Volt through-hole caps in stock.
        PlainBill
        • Wizard
          • Mar 2008
          • 2296
          Is these caps on PFC circuit? Then low ESR is necessary.
          Cheers, Wizard
          • Welchs101
            • Sep 2008
            • 979
            What is a PFC circuit?
            • Welchs101
              • Sep 2008
              • 979
              These caps came off a power supply board from an lcd monitor. Does this help?
              • PlainBill
                • Feb 2009
                • 7034
                Power Factor Correction. It's a 'front end' often found on LCD and plasma TVs. I don't think they would be used on a normal (< 24" ) monitor, but why not post pictures of the monitor and we can be sure.
                PlainBill
                • Welchs101
                  • Sep 2008
                  • 979
                  here is a pic of the power supply board.....is this what you wanted?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Yes. And to my untutored eye, they just used a pair of caps in parallel to reduce the height of the assembly. No special low ESR caps required. Still, an ESR of 85 is WAY too high.
                    PlainBill
                    • Wizard
                      • Mar 2008
                      • 2296
                      Then this one does not utilize PFC. Cap away.
                      Cheers, Wizard
                      • samoelec
                        Trying to understand how to find best replacement cap for old parts.
                        by samoelec
                        Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
                        Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
                        The power supply board is exactly the same from this post so I'll just steal it for now.
                        I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
                        04-01-2024, 03:39 AM
                      • chth96
                        Can I replace KME cap with Samxon GF cap?
                        by chth96
                        Hello.
                        I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                        Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                        I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                        04-17-2024, 07:11 AM
                      • slybunda
                        Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
                        by slybunda
                        anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
                        also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
                        if i were to replace them what should i be looking for?
                        they are on the power board of a toshiba (vestel) tv power board.
                        pic attached...
                        11-13-2023, 06:33 AM
                      • AJ847.63e
                        8th gen 13" HP Spectre X360 - Is there a MODS like utility to determine which chip is faulty?
                        by AJ847.63e
                        Hi All,
                        We've got a 8th gen 13" Spectre X360 which seems to have faulty onboard memory. Windows was bluescreening with Memory_management errors. Running HPs built in memory test brings up memory errors, but it does not tell you which chip. Is there a MODS like program so you can determine this? Memory is on board unfortunately and don't really want to go order 8 chips and replace all 8 if I don't have to.
                        Lastly do you have to use the exact same chips, or can you use chips with the same specs but from other manufactures?
                        Thanks for your assistance....
                        04-09-2024, 11:42 PM
                      • yuzupatogik
                        Help with replacing Capacitors on Altec Lansing ATP 3
                        by yuzupatogik
                        I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                        I can't find datasheets for the Samxon in any of the following variants:
                        10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                        02-14-2025, 04:11 PM
