Re: Samsung 215tw display cuts out
Thanks!
When black probe is on the middle, the resistance is 160 ohms from the outer pins. When red probe is on the middle, the resistance is increasing starting from 1 Kohm. The results are the same for the two diodes as the pins are common (I tested onboard).
I am confused, a diode shouldn't be non-passing on a way?
If these components aren't MOSFETs, what is commanding BL on and off? There aren't other 3-pins components in the inverter area. Should I check the integrated circuits on the reverse side of the PCB? If so, how can I do that?
Thanks!
But sometimes finding the fault can be difficult.
