lp156whb-tla1 Burned U21
+ More Options
Posts
  • lazaro.089
    • Jun 2014
    • 86
    • Mexico
    I have this LCD panel with U21 burned at Tcon.
    I can't seem to find what it is to look for a replacement.
    Can someone help me identify it?
  • lotas
    • Jan 2016
    • 4712
    • Russia
    Re: lp156whb-tla1 Burned U21
    This is eeprom edid (24c02), but its pinout is not standard.
    • lazaro.089
      • Jun 2014
      • 86
      • Mexico
      Thanks! I'll try to find a replacement and check if I can find EDID dump too.
      • R_J
        • Jun 2012
        • 9583
        It could be close to a M24C16-WMB6TG in a UFDFPN8(MLP8) package. I also see similar ic's marked 464F 8420
        • lotas
          • Jan 2016
          • 4712
          • Russia
          Here is the dump edid.
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
          • danielgerman681
            ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
            by danielgerman681
            Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
            08-27-2025, 01:17 PM
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
            by Vesko356
            08-11-2023, 03:27 AM
          • corrize
            Where to find a very small fpc connector 0.3mm between 2 pins ?
            by corrize
            Hello, I search this connector (oxydated).
            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
            Do you know how to find this connector please ? What is the exact name for find it ?
            08-06-2024, 05:25 PM
