E153FPf problem
  • abdo
    • Oct 2010
    • 6
    Re: E153FPf problem
    salut
    merci boucoup mr je vais ce que vous m'avez dit
    thank you very well
    • salomonthebest
      • Jan 2011
      Re: E153FPf problem
      bonjour a tous
      et bonne annΓ©e 2011 a tous le monde
      qui pourrait me donner la valeur de R1sur la carte electronique d'un ecran DELL E153FPf car la resistance est cramΓ© et j'ai un defaut de retroeclairage
      version english (thank you google lol
      hello all
      and Happy New Year 2011 has all the world
      who could give me the value of the electronic board R1sur a DELL Desktop E153FPf because the resistance is burnt and I have a default BACKLIGHT
      thank you very much
      merci beaucoup
      • Rtech
        • Jul 2010
        • 1095
        Re: E153FPf problem
        100 ohms
        • salomonthebest
          • Jan 2011
          Re: E153FPf problem
          bonjour Rtech
          et merci beaucoup , ca remarche nickel
          • Askic
            Problem with monitor DS-D5022QE-B
            by Askic
            Hello to all,
            I have a problem with monitor that is delivered together with CCTV system.
            The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
            I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
            05-31-2023, 03:14 AM
          • CptChronic
            Samsung LU32J590UQUXEN Monitor display problem
            by CptChronic
            I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
            Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
            But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
            04-24-2023, 04:33 PM
          • tmhobadcap
            LG 24MP56HQ-P Monitor Backlight problem?
            by tmhobadcap
            I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
            Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
            I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
            10-13-2021, 01:52 PM
          • tmhobadcap
            by tmhobadcap
            10-12-2021, 01:43 PM
          • Phil Stasik
            Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
            by Phil Stasik
            Pioneer Pro-FHD1 Elite. Failure to power on.
            I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
            We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
            01-19-2023, 01:22 AM
