LG Monitors, how are the caps?
  • Maxxarcade
    • Jul 2006
    • 973
    I just ordered an LG w3000h-bn to replace my TN-panel based HP w2408h. I'm concerned about the quality of the caps in the LG units though, since I've had to work on some of their plasma TV's that were full of Samwha and other cheap caps. Anyone here had to open up a newer LG LCD yet? I'm curious about the build quality. I'm also nervous about bad pixels on the LG, especially at this price level.
    The HP has been great reliability wise, and has no bad pixels, but I can't stand the dithering (6-bit RGB) and poor viewing angle compared to the newer panels.
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: LG Monitors, how are the caps?
    My December 2007 (bought in January 2008) Flatron L196WTQ-BF has Samxon GF in it. Hasn't failed yet though after two years of daily use. Nice build quality too, and a rotating stand with a metal base something you don't usually find on ~$200 TN monitors. Excellent picture as well.
    • weirdlookinguy
      • Sep 2007
      • 1638
      Maxx, did your monitor come in yet?
      • Maxxarcade
        • Jul 2006
        • 973
        Ya, I'm using it right now.
        See my comparison to my old monitor here:
        The color profile was set up wrong when I made the video... It's not that pale and green looking anymore. Nonetheless, it blew the old one away.
        http://www.youtube.com/watch?v=WsafusabUH0
        • Krankshaft
          • Jan 2007
          • 2328
          Samxon GF are CRAP replace them on sight. I've had plenty of Gateway LCDs with nearly all the Samxon GFs bulged.
          Here's a pic of them I posted back in 07 from the secondary of a Gateway LCD every single secondary bulged.
          I thought Samxon discontinued that series? This is why I stick to Panasonic, Rubycon, Nichicon, and Chemicon. I'm still wary of the Chinese companies.
          I usually leave Samxon caps alone but if I see this series it's an instant replace on sight.
          • weirdlookinguy
            • Sep 2007
            • 1638
            I should probably replace them before my favorite LCD fails on me... problem is that this LCD has RoHS soldering and I don't think my iron (40w) gets hot enough.
            EDIT: also Samxon may have discontinued the series for all we know; my monitor is starting to get old (I've had it for two years and a month now) and we all know two years is a long time in the world of electronics.
              • 31009
              you can solder lead-free with 25w.
              • Krankshaft
                • Jan 2007
                • 2328
                Just put some leaded solder on top of it to help wet it. That will help the braid suck it up.
                I used a 20W unregulated Hakko Dash for years and that's what I had to do.
                You don't have to solder lead free on the board just use leaded for the new components I always do.
                Now that I have a regulated FX-951 station I don't have to do stuff like that anymore I can just use the braid directly on the lead free. I can't believe what I was missing.
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                  by momaka
                  03-15-2023, 10:17 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • link626
                  damn. I'm disappointed these high quality caps made my power supply worse
                  by link626
                  I thought my tv power supply was stable. It's been stable for a few weeks since I swapped in nichicon, united cc, panasonic caps to replace the cheap china caps.
                  But today it caused my tv to have a flickering spasm again.
                  what a letdown.
                  I swapped back my backup power board which has cheap china caps, and the tv backlight stopped flickering.
                  Sometimes these high quality caps just don't make things better.
                  09-01-2021, 11:02 AM
