DELL P1110 Trinitron - focus problems
  • manoleo
    • Feb 2021
    Hello, I am having problems with my Dell P1110 21" Trinitron monitor. It changes it's focus on it's own. One moment it's very blurry and the next it's ok. Sometimes it's ok only in the center of the screen, sometimes only in the corners. It's very random.
    Adjusting the focus from the knobs on the FBT is not possible. I have also tried the monitor with an FBT and an A board from a working Sony FW900 but it's the same, so I'm guessing it's not the FBT or the A board.
    I read somewhere that this monitor should have an auto focusing circuit controlled by an IC. I am bad at reading schematics so can anyone please help me find this auto focusing circuit and the IC?
    I am attaching the service manual in case someone wants to check the schematics.
    Thanks in advance!
  • manoleo
    • Feb 2021
    Re: DELL P1110 Trinitron - focus problems
    I have tried to capture the problem on video but it's very hard. However on this video you should be able to see how at 0:05 the focus snaps back to normal. It happens on it's own without me touching anything. After this happens the image slowly gets blurry again until it snaps back to normal at a random moment. This goes on and on.
    Any kind of advice would be greatly appreciated.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      There is no video showing on the link given
      • R_J
        • Jun 2012
        • 9594
        If you tried a different FBT then it is likely the crt that is at fault, the focus element in the crt is going open. There is no auto focus, there is dynamic focus correction for the edge. this is controlled by the DFT transformer (H) and by Q707 (V). If the dynamic focus was the problem it would effect the edge and either the top/bottom or sides but not likely both.
        You can check the crt socket on the C Block where the focus leads are connected.
        If the focus controls have no effect it is likely that the crt is the problem.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • sviru
          Dell P1110 Sony G500 Trinitron fix - not brightness!
          by sviru
          Hi guys I have issues with my "new" P1110.
          The screen is not horizontally centered. From the start. I need to shift the screen and make it bigger to fill the screen. No matter what source xbox/pc/laptop.
          There is also a big distortion you can see here.
          https://ibb.co/NCGKs7N
          Also the screen has a little red shift in the blacks.
          Any ideas? Screen is not too bright.
          08-30-2023, 08:03 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • Caimano
          Problems extracting from Dell Bios Update.Inspiron 3793
          by Caimano
          I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
          The board is FDI45-LAJ091P REV 1.0 A00
          Processor i7 1065G7 with GPU
          This MB has 2 Bios Chips (one 8MB and one 16MB chip).
          I am trying to reload a new Bios with clean ME region, new main region and new EC region.
          I attach the dumps of the 2 chips.
          I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....
          05-04-2022, 11:19 AM
        • stakrzysiu
          Dell Vostro 15 5501 BIOS Problems
          by stakrzysiu
          i have here a Dell Vostro 15 5501
          REG Model: P102F
          SN: 1WD5103
          there is a problem that it shows screen after 1 min.
          Is this caused by me?
          Can someone clean me for me? Then i will try.
          Thank you very much
          Best regards...
          01-25-2025, 05:36 AM
