Dell P1110 Sony G500 Trinitron fix - not brightness!
    Hi guys I have issues with my "new" P1110.
    The screen is not horizontally centered. From the start. I need to shift the screen and make it bigger to fill the screen. No matter what source xbox/pc/laptop.
    There is also a big distortion you can see here.
    https://ibb.co/NCGKs7N
    Also the screen has a little red shift in the blacks.
    Any ideas? Screen is not too bright.
    Re: Dell P1110 Sony G500 Trinitron fix - not brightness!
    Hello, the red shift in blacks can be related to color calibration or other monitor settings. I think you should check the color temperature settings in the OSD menu and adjust them to a cooler temperature (e.g., 6500K) to see if it reduces the red shift. Additionally, you can try adjusting the color balance or gamma settings to see if it improves the overall color accuracy.
      https://ibb.co/NCGKs7N territorial io
      Or you can look for options such as "Horizontal Position" or "Size/Position" in the on-screen display (OSD) menu. Adjust these settings until the screen is properly centered. Refer to the monitor's manual for specific instructions on accessing and adjusting these settings. Hope that it is useful for you
