Envision EN7410
  • PincushionMan
    • 22
    Envision EN7410
    I've got a new broken one - 17" Envision EN7410. No camera today, so I'll describe everything. Pictures tomorrow.
    Problem with this one is that it randomly powers down after 5-10 minutes of use. The panel wasn't too difficult to take apart, two screws in the bottom corners and 3 hidden latches per side. Easiest to start at the bottom. Opened with a letter opener and a small cross point screwdriver, but I think I'd recommend a pair of smallish flat screwdrivers. The panel itself says 'Quanta'. To get the power/inverter board out, 6 plugs, 4 under some shiny tape, and 4 screws must be removed from a metal box unit. Flip it over and 4 more screws and removing a sheet of plastic will get the power/inverter board out. The power/inverter board has the text:
    E187621
    JIA HE
    D 94V0 (or 94VO)
    0513
    p/n: AS02B012DC2
    The power/inverter board is populated with CapXon capacitors, 2 of which are swollen and ugly, near a MOSFET, I believe.
    Here's the list of Capacitors (date code C506 so June 2005?)
    C24 470uF 25V KF/105C 10x13mm (near inverter)
    C114 100uF 400V KF/105C
    C320 10uF 50V KF/105C 4x8mm
    C661 470uF 25V KF/105C 10x13mm (swollen)
    C662 ??? has rubber shield over it ??? W-1 CS 8x12mm
    Very close to L660
    C664 470uF 25V KF/105C 10x13mm (swollen)
    I was planning on using either Nichicon HEs or Panasonic FCs, depending on what I have on hand - and what fits. After that, if it still powers off, I'll reflow the transformer points (and there's two on this one, a big one (near the MOSFET) and a little one (near the AC Input).
    Thanks!
  • eccerr0r
    inverter H tree driver imbalance in an AC inverter
    by eccerr0r
    My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
    11-16-2025, 12:34 PM
  • x_orange90_x
    by x_orange90_x
    01-29-2025, 09:24 PM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
  • eccerr0r
    A modified sine wave inverter + a grid tie inverter?
    by eccerr0r
    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
    Next thing is trying to charge the batteries using solar power, but that's another issue ...
    08-31-2023, 09:14 PM
