How to DEsolder transistor
  • Welchs101
    • Sep 2008
    • 979
    I am having a lot of trouble desoldering the transistors shown in the picture.
    I think they need replacing since there are "burn" marks around the 4 transistors. I have already replaced the bad-caps on this board and i could just try and hook everything up and see if it works but i was thinking i should go ahead and remove/replace these transistors. what doyou think?
    Definitely need help to identify a way to de-solder these transistors.
  • i4004
    • Oct 2006
    • 2029
    Re: How to DEsolder transistor
    decent wattage iron, first do the big contact(lifting gently that area (with something pointy underneath, or tweezers from above, etc.) while heating it), then 2 remaining small contacts shouldn't be a problem.
    or you can cut the 2 small contacts first, and then do the big one.
    that way you have good spot for lifting it while heating big contact.
    • Welchs101
      • Sep 2008
      • 979
      Thanks! I was wondering if i should cut the small leads. But i will try not cutting them first to see if that works.
      thanks.
      • i4004
        • Oct 2006
        • 2029
        be carefull when doing it, you don't want solder splatter in your eye if you're pulling it up too hard!
        • Krankshaft
          • Jan 2007
          • 2328
          There is nothing wrong with clipping the components leads with side cutters to aid in removal.
          As long as you don't intend to reinstall the part.
          If you don't want to clip. Place a sewing needle under the tab just make sure it stays in position don't press it in yet melt the solder now press it in. Next grab the needle and gently lift up. Just high enough to clear any solder you don't want to rip the other 2 traces.
          If you clip the other 2 leads there is no need to use a needle just push it off with the iron.
          I see darkening like that all the time it's just a result of transistor heat. The tab of the transistor dissipates it's heat through that trace on the PCB. The designers usually make that trace bigger to give more surface area for dissipation.
          It's the price we pay due to the miniaturization of technology with heatsink space at a premium.
          Did you test them with a DMM for shorts?
          No need to replace them if they aren't faulty.
            • 31102
            that's poor advice,
            if you lift the package first then you risk lifting the tracks under the pins.
            start by cutting the pins, or put the iron on the side of a pin where it touches the board, when the solder melts you bend up the pin with a small screwdriver or something like a mutimeter probe.
            once the pins are up, you put the iron on the tab of the device till the solder melts and then quickly lift it off with tweezers or longnose plyers.
            personally i just use a hot-air system.
            • Krankshaft
              • Jan 2007
              • 2328
              I use that process on 4-8 pin SOIC packages blob one side with solder melt and lift with needle. Repeat for other side.
              Never tore a trace yet.
              Anyhow as I said before this is ONLY if you want to save the component. Or if you really want to make the process easy get some Chipquik. If not clip the leads.
              • i4004
                • Oct 2006
                • 2029
                i doubt it...those traces are a bit tougher than that...and pins will bend.
                it would need to be a willful exertion of great force(once the big contact is lifted) to actually do that...
                and i don't think anybody would be doing that, unless crazy.
                either way, he can pick a way he prefers.
                any advice given here will work.
                  • 31102
                  probably worth saying for those who never lifted that type of package, that the entire package is soldered down.
                  the tab is just the end sticking out.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    I have actually removed TO252 packages (a few LCD inverters I worked on used these packages as driver transistors) I remember mentioning a few posts back something about thermal transfer. Which caused the board darkening.
                    The only way to make thermal contact without a fastener like a screw or thermal epoxy is with solder please read before you post.
                    No need to get snippy either.
                    • Welchs101
                      • Sep 2008
                      • 979
                      I decided to go ahead and leave the old ones in place and try it out. I did measure the devices as best i could with a multimeter and from what i could tell the devices seemed ok. At least comparable to the "new" devices i had ordered from digikey.
                      I put it all back together and IT WORKED. I burned it in (since my last post here) and it all seems to work well.
                      Having said all this i do really appreaciate the inputs on how to remove this device. I have routinely had trouble removing such devices and i knew there had to be a better way than what i was doing. Thanks for ALL the inputs.
                      • Jerry Hall
                        • Jul 2009
                        For the Dell/beng 2172/3fpb I clamp on a medical forcips to the heat sink and let gravity work for me. It usually results in clean holes
                        • nick122
                          Chieftec (Delta) GPS-450AA-101 A repair and possible upgrade options?
                          by nick122
                          Hi everyone!
                          I’m trying to diagnose (and perhaps even upgrade) this Chieftec (Delta rebrand) power supply from an old rig
                          The computer just stopped turning on one day. No explosions, no magic smoke, it just died.
                          There is no 5vsb, and nothing happens when I try to jump start it, it’s completely dead…
                          I took it apart and nothing looks out of the ordinary. The fuse isn’t blown and the main cap gets charged (found out the hard way lol)
                          The caps are mostly ltec with a samxon primary, none of which are bulging
                          Any ideas what I should look...
                          01-05-2025, 04:31 PM
                        • magneh
                          Behringer Eurolive B205D repair - help identifying transistor
                          by magneh
                          Hello
                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                          Still, I need to replace this transistor....
                          06-18-2025, 02:34 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
                        • Francesc V.
                          Onkyo A8200 - Not the right voltages in some transistors
                          by Francesc V.
                          Hi:
                          I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                          With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                          Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                          Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                          I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                          04-19-2025, 07:17 AM
                        • elsomer
                          help to identify transistor msi ms-15ck1
                          by elsomer
                          hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                          02-17-2025, 05:30 PM
