Originally posted by twist3r
View Post
So it appears to be a voltage detector / reset IC - something to do with the HDMI line and it's not a voltage regulator like I thought it was. Going by the voltage readings you posted, it appears to be working normally as far as I can tell.
View Post
It's nothing special though. Just a 5 Watt, 5.1 KOhm resistor. I got it out of a scrap CRT TV board a long time ago. A lot of time I don't even use it. If all I'm trying to do is discharge a mains (big) cap and I have easy access to the cap leads, I usually just use the plug on my 30 Watt regular (simple wall plug-in type) soldering iron and place it directly on the cap leads.
Since I live in a country with 120V AC, the resistance of that iron is approximately (V_AC^2) / P = (120^2) / 30 = 14400 / 30 = 480 Ohms... which is a bit low, but not that bad for discharging caps, since by the time any significant current starts flowing, the cap is already mostly discharged.
I do NOT recommend using incandescent bulbs to discharge big caps, though. The higher voltage can sometimes blow the filament of the bulb, since incandescent bulbs have lower resistance when they are cold. I managed to blow up two like that.
In place of one big resistor, you can also solder 2 or 3 smaller resistors in series and cover with heatshrink tubing. 3x 47-100 KOhms should do the trick. And because you have 2-3 resistors, they can be each 1/2 to 1W only, instead of higher power... so this may be cheaper to build.
View Post
Also, lower resistance = faster discharge, but also more power dissipated by the resistor.
Generally, this shouldn't matter too much with the caps we deal in regular electronics like this monitor.
So any resistance between around 1 KOhm and 100 KOhms will probably do. If it's a 1-10 KOhm resistor, then I suggest going with one rated for maybe 3-5 Watts. Probably can do fine with less too, but just to be safer. If you go higher in resistance... say 20-40 KOhms, you can probably use just a 1-2 Watt resistor. And for 50-300 KOhms, 1/2 to 1 Watt should be OK.
View Post
From your monitor, I think it's the 24V DC rail that goes through a set of MOSFETs that then pulse (or "chop", if you like) On and Off that 24V rail into a transformer. The pulsed output of these MOSFETs is basically a square wave with peaks up to 24V... which is a type of AC voltage. Once this 24V "chopped" AC goes through the inverter transformer (because transformers can only work with AC, regardless if it's nice and sinusoidal like the AC at your wall or square pulse, like from the MOSFETs), the output of the inverter transformer is wound to make roughly 700-1200V AC (which will also be a square wave, BTW.) This high-voltage AC then goes directly to the CCFLs through a set of small coupling capacitors. And that's all there is to it, really.
So essentially, the inverter takes low voltage and high current to produce high voltage and low current needed for the CCFLs. Although I say "low current" here, the current can be 5-10 mA at the high voltage output, which is enough to be lethal. On the positive side, since the inverter switches at high frequency (typically 50 KHz or more), this high voltage is also high frequency... and high frequency current tends to flow more on the surface of the skin rather than go deeper through nerves and muscles. So that makes it slightly less likely to be lethal... but still, DON'T TOUCH THE INVERTER WHEN IT'S OPERATING.
View Post
View Post
Only those small blue/orange disc caps near the inverter transformer can be charged... but they discharge almost instantly too, the moment power is unplugged. And they are very small capacity as well. So inverter area is safe after power is removed nearly instantly.
View Post
That said, I forgot to ask... what voltage do you get on the 18V rail when PSU board is plugged in the wall but logic board DISCONNECTED from it (i.e. only have PSU board plugged in the wall and check voltage on 18V rail.) I'm just curious if the PSU board self-turns On or not in the lack of signal from the logic board.
View Post
