Re: LG Flatron L17NT-A no power
Ok Plainbill,
if i knew what i was doing i wouldn't be on here..:-) <bk>
i will try to be more precise from here on out <bk>
i crossed the filter @ junction C101 and got 160.8 dcv <bk>
@ connector CW201 pin6 =5 dcv. and pin7= 5 dcv , pin10=13.78 ,pin 11=13.78. <bk>
8pin ic @ U101 i jumped pin 1 and 5 and got 115 dcv. <bk>
thats how i determined the power board was in good shape. <bk>
now for the logic board the parts you circled.<bk>
U202= 3 TERMINAL LOW DROP OUTPUT VOLTAGE REGULATOR part#kia78D33F
i had 4.4 dcv going in and 3.0 coming out.<bk>
U203= PART#LD18 it is a 3 prong surface mount made by STmicro but could not find a data sheet or that part either? but i had 3.0 dcv on pin 3 and 1.5 dcv on the drain. <bk>
U407= 3 TERMINAL LOW DROP OUTPUT VOLTAGE REGULATOR #Kia78D33F i had 3.4 dcv. in and 2.1 dcv. out.
datasheet.
Ok Plainbill,
datasheet.
it's always good to have a place to look for help when things go bad.
i replaced all caps and it works again!! thanks to all!
