Dell ST2421LB Dead monitor
  • jason123
    • Oct 2015
    • 1154
    Hi there,
    got this monitor that looks great cosmetically, but no life. After a bit of a struggle, I opened it up. I am getting 160 V across large cap. No voltages on the connector that goes to main board. If this is anything like TVs, I'd expect some standby voltage to the main board.
    I am not familiar with this power supply board 4H.17B02.A00
    I found an IC that's close to the mainboard connector, thinking it might be the standby regulator. Has the folowing numbers on it
    101058
    1T10231
    No luck with any datasheets on this.
    help!
  • jason123
    • Oct 2015
    • 1154
    Re: Dell ST2421LB Dead monitor
    Correction, under a microscope, the I closer to the main board connector is 210105BA (not 101058) But this IC is not getting any voltage, so I don't believe it's the problem.
    Thank you
    • diif
      • Feb 2014
      • 6978
      • England
      It's the TOP258PN next to the main cap.
      • jason123
        • Oct 2015
        • 1154
        Thanks. That IC has 160 V on pin 4 (Bottom left - below the missing pin) and all zero volts (reference to negative leg of large cap) on all other pins
        • R_J
          • 9624
          You can check that ZD601 is'nt shorted, but it's likely the TOP258 ic is bad, the internal soft start is likely bad. You should have around 5.8v on pin2
          • jason123
            • Oct 2015
            • 1154
            Thank you. Diode is not shorted. IC is on order
            • jason123
              • Oct 2015
              • 1154
              Hi . Got a new ic in place and same result. Probing around, I found that C611 was shorted - Replaced and Monitor is back up and running. Thank you for the help.
              • Rodoz
                • Aug 2021
                • 3
                does anyone know what the zener diode ZD601 is on this ps board
                • R_J
                  • 9624
                  I believe it is a 9.1 volt, BZV55-C9V1
                  • Rodoz
                    • Aug 2021
                    • 3
                    Hi R_J, many thanks for your resonse. The ZD601 on mine is S/C and naturally the supply wont run. I could not find the schematic anywhere and there is no info printed on this surface mount diode so your information is very handy. Much appreciated, regards from Rodoz
                    • lotas
                      • Jan 2016
                      • 4898
                      • Russia
                      ZD601 - 20v
                      • R_J
                        • 9624
                        I don't have the exact schematic but this one is similar and uses the same top258pn
                        You may need to clean the top of the diode with alcohol to see the marking code.
                        • lotas
                          • Jan 2016
                          • 4898
                          • Russia
                          Yes, you need to look where it (ZD) stands according to the scheme and its marking.
                          • llphat
                            • 20
                            Could anyone help with the value for C607 please. I have the same board 4H.17B02, zener ZD601 appear shorted in circuit but once taken off PCB appear OK. Took off C607 but found pads for ZD601 still shorted eventually found that it was C608 47uF 25V that was shorted. However in the process of taking off C607 end terminals was destroyed.
                            Anyone would could help with value of C607 would be much appreciated.
                            Tried 80nF which gave approximately 5.8V at pin2, ~1.26V at pin1 and 330V at pin4 of TOP258PN.
                            Thanks.
                            • R_J
                              • 9624
                              C607 seems to be 0.1µf. If C608 was shorted, check if R606 is open or the opto ic could be bad.I would also replace C611. C607 is just to remove any high frequency noise on the line, its not that critical and should operate without it.
                              5.8v on C (pin2) is supplied by the ic, Once the circuit starts, the control voltage for pin 2 comes from D602/C611 through the optocoupler.
                              • llphat
                                • 20
                                R606 measures 6.6ohm in circuit. C611 checked OK approx 10uF out of PCB.
                                I could see 340V (against negative leg of C605 large filter cap) on the Pin 1,2 and 0V on Pin 4,5 on primary side of the transformer T601, but no output voltage on the secondary side (pin 6/7, pin8/9 and pin10), does this mean transformer is broken?
                                • R_J
                                  • 9624
                                  It does not mean the transformer is broken, it means the circuit is not operating. Have you looked at the datasheet to understand how the ic operates? Replace the two capacitors I suggested
                                  Check the voltage on pins 3 & 4 of the optocoupler (using hot ground as meter ground)
                                  • llphat
                                    • 20
                                    Unfortunately I do not know enough about how the circuit works.
                                    pin3 on the optocoupler measures 5.84V (against hot ground) which is the same as pin2 on the TOP258PN IC which it is connected to. pin4 on the optocoupler measures 7.96V against hot ground, so about 2.12V when measured across pin3-pin4 of the optocoupler. Across pin1-2 of the optocoupler measures about 1.126V.
                                    On the TOP258PN IC, pin4 measures ~337V, pin2 (=pin3 on the optocoupler) is 5.84V, pin1 is about 1.26V.
                                    Thanks for your patience.
                                    • keepread
                                      Dell monitor PSU vs Dell laptop PSU
                                      by keepread
                                      Hi there!
                                      Someone gave me their old monitor, it's Dell S2715ht.
                                      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                      10-30-2025, 04:45 PM
                                    • Borse2008
                                      Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                      by Borse2008
                                      Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                      I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                      • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                      • There’s
                                      07-15-2025, 04:55 AM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • DanPoka
                                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                      by DanPoka
                                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                      02-15-2025, 05:05 AM
                                    • Asraf Atb
                                      by Asraf Atb
                                      01-27-2025, 05:02 PM
