Gateway VX900 Buttons Sticking
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    I have and Old Gateway VX900 monitor. It has 12 momentary buttons under the CRT screen. The two for the Brightness, and Contrast have stopped "clicking" and must be pushed and rocked from side to side to get the setting to change. Can I get the daughter board out of this monitor without electrocuting myself? I have many different styles of momentary switches that I have saved from other things that I have junked. I just might have the right ones to replace my bad ones with.
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
  • LEEDASH
    Aiwa TX-110 Tuner Buttons
    by LEEDASH
    Hello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
    Thank you
    05-07-2024, 02:41 PM
  • bobbyskillz
    Vizio E241i-a1 - works, but OSD stuck and no buttons work
    by bobbyskillz
    Hello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
    I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
    Thanks for...
    07-02-2025, 03:43 PM
  • bjhnsonjr2734
    Gateway laptop model GWTN-156-7BL Needing Schematics
    by bjhnsonjr2734
    I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
    I attached a pic of motherboard info
    04-25-2025, 07:01 AM
  • Dan John
    Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
    by Dan John
    Greetings everyone,
    I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
    1) On pressing the power button, the (power button) light turns on and stays on.
    2) There is no boot, or anything on the screen.
    3) The fan starts and stops a few times, then it stops completely.
    4) The light on the power button remains on.
    5) Battery not charging (original issue).
    The original problem was that the battery was not charging, but the laptop still worked. My belief
    04-23-2025, 08:12 AM
  • aes1111
    need bios for gateway GWTN156-12BL
    by aes1111
    Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
    S/N 2GWTN15612BL2J21J008090...
    01-02-2025, 07:23 AM
