I have and Old Gateway VX900 monitor. It has 12 momentary buttons under the CRT screen. The two for the Brightness, and Contrast have stopped "clicking" and must be pushed and rocked from side to side to get the setting to change. Can I get the daughter board out of this monitor without electrocuting myself? I have many different styles of momentary switches that I have saved from other things that I have junked. I just might have the right ones to replace my bad ones with.
Gateway VX900 Buttons Sticking
Mark Twain
John Paul Jones
Rod SerlingTags: None
by LEEDASHHello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
Thank you1 Photo-
by bobbyskillzHello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
Thanks for... -
I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
I attached a pic of motherboard info
04-25-2025, 07:01 AM -
by Dan JohnGreetings everyone,
I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
1) On pressing the power button, the (power button) light turns on and stays on.
2) There is no boot, or anything on the screen.
3) The fan starts and stops a few times, then it stops completely.
4) The light on the power button remains on.
5) Battery not charging (original issue).
The original problem was that the battery was not charging, but the laptop still worked. My belief...5 Photos -
by aes1111Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
S/N 2GWTN15612BL2J21J008090...-
Channel: BIOS Requests ONLY!
- Loading...
