Dell p2414h ips led
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Dell p2414h ips led
    Have a problem with this monitor ...
    It has a vertical yellow line on screen,the line is a little right from the middle ...
    Is there any way to fix it ???
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Re: Dell p2414h ips led
    Any one ??
    Any advice where to start searching ??
    It's a yellow lie from top to under, on the "new" on screen
    thx
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      You most likely have a loose contact where the ribbons are connected to the glass with glue, it is very difficult to fix.
      You can try to apply a little pressure to the ribbon closest to the line and see if it goes away, if it does add a pressure pad and put screen together and if not replace screen.
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        thx for info
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
        • diamon
          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
          by diamon
          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
          Pictures of these boards:
          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
          Dell...
          02-28-2024, 12:51 PM
