Dell p2414h ips led
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Dell p2414h ips led
    Have a problem with this monitor ...
    It has a vertical yellow line on screen,the line is a little right from the middle ...
    Is there any way to fix it ???
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Re: Dell p2414h ips led
    Any one ??
    Any advice where to start searching ??
    It's a yellow lie from top to under, on the "new" on screen
    thx
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      You most likely have a loose contact where the ribbons are connected to the glass with glue, it is very difficult to fix.
      You can try to apply a little pressure to the ribbon closest to the line and see if it goes away, if it does add a pressure pad and put screen together and if not replace screen.
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        thx for info
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
