AOC LM2028 - no voltage
  • neutrino68
    • Sep 2010
    • 9
    Re: AOC LM2028 - no voltage
    Ok, here's my readings, all relative to pin 1:
    Pin 2: 1.49V stable
    Pin 3: 16.65V stable
    Pin 4: 1.29V stable
    Pin 5: 0V
    Pin 6: 0.01V to -0.01V (constant and fast fluctuation around 0V)
    Pin 7: 13.48V stable
    Pin 8: looks like Pin 6
    • jetadm123
      • 2169
      You might try checking the current sense resistor off of pin 6. It's probably a 2 Watt resistor that's 0.33-0.39 ohms. Check the resistance. If this resistor is bad, it will prevent the SG6841 from starting up.
      • neutrino68
        • Sep 2010
        • 9
        Originally posted by retiredcaps
        Here is what I think is the relevant portion of the datasheet.
        == snip ==
        Under-voltage lockout (UVLO)
        The turn-on and turn-off threshold of SG6841 are fixed internally at 16V/10V. During start-up, the hold-up capacitor must be charged to 16V through the start-up resistor so that SG6841 will be enabled. The hold-up capacitor will continue to supply VDD before the energy can be delivered from auxiliary winding of the main transformer. VDD must not drop below 10V during this start-up process. This UVLO hysteresis window insures that hold-up capacitor is adequate to supply VDD during start-up.
        =end snip ==
        This means 13.48V on VDD is too low for the controller to be enabled, then? Or is it 16V initially and drops to 13.4 after the startup process?
        • neutrino68
          • Sep 2010
          • 9
          Ok, I think that resistor is between the heatsink and the huge cap beside the rectifier bridge, it's covered with heat-shrink tubing so I can't see its resistance value. I'll peel it tomorrow and check it. Now to bed.
          • retiredcaps
            • Apr 2010
            • 9271
            The same thought you had occured to me as well.
            If this were the enterprise networking world, I could easily, in a few seconds, tell you by hooking up a couple of protocol analyzers. The protocol analyzers would capture the initial packets and I could tell you.
            We may be able to deduce if the SMPS has started or not by looking at the other voltages.
            Back to some more reading.
            --- begin sig file ---
            --- end sig file ---
            • PlainBill
              • Feb 2009
              • 7034
              OK, I'm going to come to the rescue. You've done a good job of troubleshooting, mainly following the same path I went through the first time I ran across one.
              The idea of a bad cap on pin 7 is good, but if it's dried out and the capacitance has dropped the usual symptoms are a pulsing voltage at the outputs and at pin 7. The voltage at pin 3 comes from the big cap, dropped through one or more resistors. The app note calls for a total of 1.5 megohms. I think this uses a pair of 430K SMD resistors and a 680K through hole. Notice that the voltage on pin 3 is sort of low. The datasheet recommends a target of 20 volts with a maximum of 30 volts. There is a zener diode in the chip to set that limit. Note that at 16.65V it really can't pull pin 7 up to the start threshold.
              Now there are two possibilities. Either the resistors have increased in value, or the current draw has increased. It was about this point where someone else stepped in and pointed out that he had repaired a number of monitors by replacing the SG6841.
              PlainBill
              • Fernon@Repair
                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                by Fernon@Repair
                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                VCCIO voltage ok
                VCCSA Voltage OK
                VCCPLL Voltage OK
                Ram Voltage ok
                RamVTT OK
                VPP 2.5 OK
                But No Core Voltage
                and i want to this vrm ic datasheet or pinout (ISL69269)
                anyone have this ic pinout voltages?...
                06-25-2025, 07:19 AM
              • electron_jj
                Panasonic TH-L42D25A checking the PSU output voltage
                by electron_jj
                Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                08-29-2021, 08:13 AM
                Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                Now...
                06-09-2024, 10:57 AM
              • TJM2005
                DSP-167DP LOW VCC at IC901
                by TJM2005
                I am trying to repair a power supply for a Vizio M492i-B2.
                Before I started:
                Fusible Resistor R915 was open.
                ZD909 was shorted.
                D950B was shorted.
                I have replaced the above parts along with a new IC901 / LD7913J
                I now have:
                165V on the main cap
                IC901 Drain pins: 165V
                IC901 VCC: 1.1V
                IC901 COMP: 1.1V
                IC901 BNO: 0.3V
                I pulled the Q800 Mosfet and it checked good.
                I also tested the two smaller caps C907 and C904B, they both tested close to the rated value.
                Does anyone know of anything...
                10-12-2025, 12:04 PM
                ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                Based on Intersil's Robust Ripple Regulator...
                11-05-2024, 03:24 PM
