Benq FP951 Invert/CCFL
  • mdegan
    • Nov 2009
    • 6
    After reading through the forum trying to find info on my faulty Benq FP951.
    I have tried a couple of things.
    My issue is no display, the power light stays on (Green).
    If I shine a light at the screen I can make out a very faint image.
    I have checked all the invert joins (all 22 of them, hope I'm looking at the right component) and replaced the 4 c5707's and the pico fuse.
    Still the same issue, once it displayed an image for about 2 seconds and then back to nothing.
    It has 4 individual CCFL tubes, if one has failed will it stop the rest from working?
    Any help would be appreciated as I have not been able to find any info directly relating to the FP951.
    Cheers
    Michael
  • Bobdee
    • Jun 2008
    • 461
    Re: Benq FP951 Invert/CCFL
    Cheers
    Michael
    Hello Michael
    This is possibly a CCFL failure,as you suggested
    If one fails then Inverter turns itself off
    Have you resoldered the four Inverter Transformers??? (there is more than 22 joints between them)
    Was the old fuse open???
    Was there any shorts in old transistors???
    Or did you just replace them hopeing it would fix problem (as it can do)
    • mdegan
      • Nov 2009
      • 6
      Originally posted by Bobdee
      Hello Michael
      Hi Bobdee,
      Thanks for your reply, I just replaced all 4, hoping it would fix it.
      There are only two inverter transformers on the board and each has 11 points.
      To answer your question, no I have not yet I'm just about to start.
      This is my first time doing anything like this it's only the second time I have used a soldering iron .
      I'm not 100% on how to check if the fuse is open (I will search around now to find out)
      Same answer to "was there any short on the old transistors", I;m not sure how to check just browsing youtube now look for a good how to.
      • mdegan
        • Nov 2009
        • 6
        Just checked fuse and both are closed. New and old one.
        I tested with DMM in continuity mode and DMM beeped.
        So I take it that means it's closed ??
        • Bobdee
          • Jun 2008
          • 461
          Correct
          You can test your old transistors same way
          Leg 1+2 1+3 2+3 But you should get no beeps on good ones
          But my guess is they will be ok
          So then you will need to get hold of a case mod kit to check your CCFLs
          • mdegan
            • Nov 2009
            • 6
            Correct
            Just tested all 4 transistors and no beeps from any of them.
            So next on the list, work out what/how to use a case mod kit to test CCFL's
            Thanks for your help Bobdee!
            • mdegan
              • Nov 2009
              • 6
              Just had a thought, I can get my hands on the same model screen and do some part swapping.
              Is there any chance I could damage the other working screen if I put the power/inverter board in it? I don't want to kill the other screen
              • Bobdee
                • Jun 2008
                • 461
                That sounds good but it looks like your Inverter is working (and possibly always have) so best left at moment
                If you have screen with known working CCFLs at least one pair then disconnect a pair of top CCFLs connectors off your monitor and plug in a pair of CCFLs off the spare screen, power up and if they stay on then you have found problem, if they dont, try the same with bottom pair
                • PlainBill
                  • Feb 2009
                  • 7034
                  There should be no problem trying your power supply / inverter with another LCD panel. I am a little confused by your description of the problem, however.
                  A little background: The usual backlight design consists of an inverter and several CCFLs. The normal operating sequence is the monitor controller 'tells' the inverter controller to turn on the backlights (and how bright). The inverter controller drives the CCFLs to full brightness, then several seconds later begins monitoring the voltage across each CCFL and the current through each of them. If eithr voltage or current are too high or too low, the controller will shut down all CCFLs. There is no signal line to tell the monitor controller this has happened, so the power light stays green (or blue). This is the infamous 'two seconds to black problem.
                  You have already noted that a faint image can be seen. Another symptom is to turn the monitor off, then on again using the front power button. Usually each time you do this the backlights will come on for a few seconds.
                  There are three possible causes of this problem: A failure in the inverter drive system (bad transistors, open transformer, etc); a failure in the CCFLs (broken CCFL, 'worn out' CCFL, arcing in the wiring); or a failure in the monitoring components (open or shorted diode or transistor). One limitation of the case mod kit is the inverter doesn't monitor the voltage or current. Bobdee's suggestion for using the CCFLs in the other monitor is an excellent way to test.
                  PlainBill
                  • mdegan
                    • Nov 2009
                    • 6
                    Inverter is working correctly.
                    I have removed the 2 sets of CCFL's and both look fine, no obvious defects.
                    Were is the best place to buy replacements?
                    I'm in Australia, in saying that I'm not fussed if they have to be shipped over just dont want to wait months for them to get here.
                    • Bobdee
                      • Jun 2008
                      • 461
                      You can run them out of the screen with care, then you can see what one is not working in the couple of seconds that they come on (bad ones can come on with a redish tint)
                      It has been known for them to have a faulty connection on the ends of some tubes (worth checking out on the bad one/s carefully)
                      Cant help you on where to buy as I have never had to buy them, I have plenty of non working screens stored for when I need them
                      Good Luck
                      Bob
                      • ttmi100x
                        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                        by ttmi100x
                        Greetings everyone,
                        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                        Upon closer inspection...
                        07-31-2024, 06:36 PM
                      • mikey5791
                        Help on Samsung Syncmaster T220 dead ccfl lamp
                        by mikey5791
                        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                        10-18-2020, 03:17 AM
                      • seppde
                        Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                        by seppde
                        I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                        ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                        The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                        In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                        02-09-2024, 05:19 AM
                      • AJ847.63e
                        BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                        by AJ847.63e
                        Hi All.
                        Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                        The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                        09-18-2023, 06:42 PM
                      • ChatBTC
                        Benq EX3501R
                        by ChatBTC
                        Hi!
                        I am new to this site, and found it via LLM ChatGPT.
                        I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                        01-24-2025, 08:49 PM
