Dell 1901 Service Manual?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, does anyone have a service manual for a Dell 1901FP?
    The power button PCB and cable is missing, I just want to short the correct pins to see if it turns on, all PCB's and components visually look to be in pristine condition!
    I think the power button PCB is supposed to connect to the lower left header on the PCB, I have not seen one tho so I'm not sure...
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell 1901 Service Manual?
    At the risk of being 'The one who says it can't be done', it may be a little more complicated than that. Some monitors (and TV sets) use a voltage divider on the push button circuit board. The voltage on the line back to the controller is important.
    PlainBill
    • ecking767
      • Oct 2009
      • 492
      I happen to have this board on my work bench for testing. The Off/on connector is P308. That the top right header. I don't have a service manual
      • Toasty
        • Jul 2007
        • 4171
        It's the flat ribbon cable connector at the bottom left corner in your picture.
        I'd use a resistor to jump the connection, not a wire. Maybe start at 4.7kΩ and come down from there. I had my 1905FP open a few weeks back, but no pics of the control board. It's simply push buttons with a few of LED's & resistors.
        See attached pic.
        veritas odium parit
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Thanks guys, I figured as much as I wrote in my original post that "I think the power button PCB is supposed to connect to the lower left header on the PCB" (meaning the location in the picture I posted obviously)
          Anyway, I'd still like to know the pinout, I just don't wanna start shorting pins on gut feeling
          • PlainBill
            • Feb 2009
            • 7034
            You can get close with a little detective work. It is most likely that 1 of the 7 pins is 5V (perhaps with current limiting). One is certain to be ground, another is the drive for an LED.
            Toasty's suggestion would eliminate the chance for any damage while allowing you to determine the correct pin empirically.
            PlainBill
            • Toasty
              • Jul 2007
              • 4171
              I think the 1901 uses a soft-touch power on/off on that board too. Momentary contact switches logic states.
              The 1905FP is that way, but the 2005FP uses a mechanical latch on/off pushbutton. 2005FP is a BenQ in Dell clothing.
              veritas odium parit
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Was going to chuck the thing in the trash today but could not get myself to do it, it looks so nice
                So I got the DMM out, pin 1 and 2 are common and are ground
                On pins 3>6 there is 1.8v and it slowly rises when I have the DMM on it measuring
                On pins 7 and 8 I get no reading
                What's my safest bet here would you say to start with?
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  pic of connector;
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Look at the layout.
                    Possibility 1: 1 & 2 are ground. 7 & 8 are the drive lines for the power / standby LED. (Note they are connected to transistors Q307 & Q308.) Note also resistor networks RN314 and RN315. RN314 provides a 10K pullup, RN315 is for isolation. Test by pulling pins 3-6 to ground through a 4.7K resistor (1 pin at a time). If that doesn't 'wake up' the monitor, try a 2.2K, then no resistor.
                    Possibility 2: 1 & 2 are ground. 3-6 are the X lines while 7 & 8 are the Y lines in a 4 X 2 drive / sense array (or a 4 X 2 sense / drive array). Clip one end of a short jumper to pin 7, then touch the other end one at a time to pins 3-6, pausing a few seconds between each pin. If you don't get any response, try using pin 8.
                    The identity of Q307 & Q308 will help distinguish between the two possibilities. Given the difference between the current limiting resistors (R365 & R367), I would say Possibility 1 is most likely.
                    Also, why not look up the datasheets for the Genesis IC? Granted, locating this may be difficult, so also examine schematics for any monitor using a Genesis controller.
                    For additional ideas, look at the circuit in the lower right hand corner of page 42 of this manual. Note that one has the circuitry on the logic card; others place the circuitry on the button pc board.
                    PlainBill
                    • Regent
                      Computer Tech
                      • Dec 2011
                      • 32
                      Would anyone have the service manual for the Dell 1901FP LCD? I have that model with a missing circuit board that goes behind the volume & display control buttons. I need the part number of that board so that I may order a new one!!
                      Hope someone could help me??
                        LCD LED TV Service Menu Codes
                        ALL LCD LED TV SERVICE MENU CODES
                        Service Menu Code with Board Name
                        China Universal Board / Jumper Board Service Menu Code
                        Changhong Ruba Service Menu Code
                        Ecostar LED TV Service Menu Code
                        Orient LED TV Service Menu Code
                        Haier LED TV Service Menu Code
                        TCL LED TV Service Menu Code
                        Samsung LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        Videocon LED TV Service Menu Code
                        Supra LED TV Service Menu Code
                        Toshiba LED TV Service Menu Code
                        Symphony LED TV Service Menu Code
                        Veste/ LED TV Service Menu Code...
                        10-31-2024, 03:58 AM
                      • AustinCER
                        Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                        by AustinCER
                        Hello, I currently have a Dell XPS 8940 in our office for repair.
                        Service Tag: HG1Y673
                        The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                        Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                        Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                        07-15-2025, 05:28 PM
                      • techman125
                        Dell Latitude 5500 series change service tag (serial number)
                        by techman125
                        Hello.
                        I hope I'm in the right forum.
                        I have been searching for quite a while, before finding this site.
                        I frequently replace mainboards in the Latitude 5500, 5510 and 5520 models.
                        Changing the asset tag is pretty straight forward, but from what I've read changing the service tag isn't possible unless you can use a CH341A programmer and hex edit the bios.
                        Dell would probably be able to do it but sending them a used board and paying them defeats most of the cost savings over new.
                        While testing a used board and swapping parts, a 5510 just out of...
                        05-04-2025, 07:34 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • lzeta
                        Dell Latitude 5410 service tag
                        by lzeta
                        I have a dell 5410 with locked bios, than I dump bios from a identical laptop and I've flashed it. But now all system information are identical to the bios donator laptop, how can I write again the correct service tag and other infos? I attach the original loched bios bios, how can I extract the right infos? And how can I write it?...
                        10-07-2025, 10:19 AM
