Where to buy a k2717 mosfet?
+ More Options
Posts
  • morgan
    • Nov 2009
    • 12
    I've looked at all my known sources to find this (now discontinued) mosfet and i don't know know enough about them to know what would make a suitable replacement.
    this is the datasheet
    https://cdn.badcaps-static.com/pdfs/...8291eddc8a.pdf
    seems to be what's making my tv not work... i've tested it and it's bad. whether it's the only thing that's bad remains to be seen. hopefully there's no magic smoke in my future.
  • Bobdee
    • Jun 2008
    • 461
    Re: Where to buy a k2717 mosfet?
    Hello
    This link should help
    http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      The membership here is world wide.
      - Giving your location would help you get better answers.
      http://www.signalsuk.com/signalsuk.n...D?OpenDocument
      http://cgi.ebay.com/ws/eBayISAPI.dll...m=250371330868
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        These look pretty close but someone else double check please:
        http://search.digikey.com/scripts/Dk...me=2SK3742Q-ND
        http://search.digikey.com/scripts/Dk...e=2SK3565QM-ND
        - Dr Seuss
        • PlainBill
          • Feb 2009
          • 7034
          Bobdee has the good information. The original part number is available on eBay from a source in Malaysia. Total including shipping is $12.00
          PlainBill
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • Nooy
            VGA MOSfet permanently shorted and loss of MOSfet pad
            by Nooy
            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
            02-14-2024, 02:26 AM
          • jaifraic
            Allen & Heath Xone:92 (DJ mixer) no output on main out & magic smoke
            by jaifraic
            I have a DJ mixer here, an Xone:92 by Allen & Heath.
            When I turned it on, only magic smoke came out, so I turned it off again.
            An optical troubleshooting has brought me quite fast to the
            source of the smoke: two resistors look disproportionately black (see first pic)
            Those are R73 and R74 on the master PCB. See second pic for the corresponding page of the service manual.
            Behind those resistors are five OP-Amps (U3, U4, U5, U6 and U9).
            My thought is that one (or more) of those is defective. I've measured...
            03-15-2022, 12:32 PM
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
          • MicroSMD Lab
            ASUS ROG Zephyrus GPU Mosfet repeat failure
            by MicroSMD Lab
            The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
            01-10-2024, 06:36 AM
