hp 19"
  • hydafl
    • Jul 2009
    • 18
    hp 19"
    Just wanted to give a hardy thank you. Due to this site and the info I was able to repair our 19" monitor last night. It was a first for me. The info about the caps and the how to install was fun and not as difficult as I had thought.
    Just something good to share.
  • golemmaster
    • Jul 2009
    • 100
    Re: hp 19"
    Excellent! Glad to hear it. Empowering, isn't it? Knowledge, that is.
    • hydafl
      • Jul 2009
      • 18
      Re: hp 19"
      yes knowledge is the key. I've worked on cars for many years, and having installed new parts, I would have liked to know what was wrong with the part. a small step...
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • 24gsm
        MacBook Pro A1708 install macos fail
        by 24gsm
        hi to all
        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
        after enter to recovery and format hdd 1to .
        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
        can help please
        Serial Number: FVFXP0U0HV2J
        Config Code: HV2J
        Find My Mac: OFF
        04-16-2025, 03:57 AM
      • duwane
        A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
        by duwane
        Hi All.
        Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
        The issue:
        Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
        10-26-2022, 07:02 AM
      • tommy97
        ASUS FA507R - BLOD, cannot install windows
        by tommy97
        I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
        I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
        08-22-2025, 07:55 AM
