The longest repair ever
  • mastakilla
    • Jul 2015
    • 14
    • Italia
    Hello! I have a beautiful 30" LG W3000H lcd monitor which I used up until 2 or 3 years ago: then it started flickering along with portions of the picture moving up and down on their own.
    Brought twice to an LG repair centre, the final diagnosis was "it's the panel", and of course the panel was more than a new monitor.
    Bit the bullet and bought another monitor, but didn't throw away the LG as I hoped to fix it one day.
    Fast forward to today: I suspected the tcon, so bought a replacement on aliexpress for the pricey sum of 30 dollars, and it seems to have fixed the flickering problem! Unfortunately, it exhibits another issue: the picture is split vertically in the middle and is shrinked and duplicated on the left and right side: it's like on the left side of the monitor it displays only even columns while on the right only the odd ones. I noticed that the tcon I received is slightly different from the original, it has the same code (LM300WQ5-STA1 6870C-0183D) but some resistors close to the flat ribbon connectors are soldered in different positions, and there's a small chip and a bunch of resistors missing elsewhere.
    Now I know that the panel is fine, and I ordered another tcon (for 20 dollars this time) that looks to be identical (the code is actually different, 6870C-0183E, but the resistors layout is the same). If I succeed, that will be 3 or 4 years to fix a monitor!
    Failing that, is there a way to trick it into displaying the picture correctly? Maybe swapping some wires in a DVI cable?
    Thanks!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: The longest repair ever
    Doesn't count unless you opened and left it open (not buttoned back up) until you finally fixed it
    Reminds me of that stupid 120VAC inverter I got that failed, had it opened up for at least a few years, screws put in a little plastic cup, until I finally rootcaused and fixed it. I was lucky to find all the body components and able to put the thing back together like what it was when I bought it, minus that stupid SMT resistor that failed just days after I got it...
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Im with ECC on that. Ive had a project in pieces for more then a decade, lol
      Follow the white rabbit.
        master hoarder
        • May 2008
        • 12170
        I'm guilty of that as well.
        Also have many PC project parts in boxes that have been waiting to be built for years.
          by momaka
          03-15-2023, 10:17 PM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
