Envision EN-5200ci recap (success)
  • geforcefly
    • Jul 2006
    • 33
    Envision EN5200ci TFT1560PS 15" LCD: Display backlight stayed on for a split second, showing faint picture. PSU (715L1034-1) had bad caps.
    Caps:
    6x Hermei 470uf 16V replaced with 6x Panasonic FC 470uf 16V
    2x Hermei 1,000uf 16V replaced with 2x Panasonic FC 1,000uf 25V
    1x Hermei 150uf 50V replaced with 1x Panasonic FC 150uf 50V
    1x Hermei 100uf 400V replaced with 1x Panasonic EE 100uf 400V
    Before and after pictures included
    Yes, the cap nearest the heatsink is sitting high up, I didn't pay attention to the diameter sizes when ordering the caps! This was my first ever recap, so I feel proud about that. This monitor will last a long time.
  • japlytic
    • Oct 2005
    • 2086
    Re: Envision EN-5200ci recap (success)
    Did you also replace the small capacitor near the MOSFET on the primary side? It is a good idea to replace it too.
    The power supply looks almost identical to the HP C1502 power supply, except for the mains connector.
    Last edited by japlytic; 09-19-2009, 07:01 PM. Reason: Potential for misinterpretation
    • geforcefly
      • Jul 2006
      • 33
      The small cap by the mosfet without the heatsink was not changed. I didn't think it would be problematic. If the display acts up again I will change it. This is because when I have to change it I don't want to wait a long time for the PSU to completely drain (I always assume no bleeder resistor and I didn't have what I needed to drain the PSU; can't merely trust the switch!) I'm new at doing this and don't want to zap myself (which is also why I'm afraid to touch the innards of an ATX power supply that was just unplugged, except for the fan).
      At least now I have one spare LCD :-)
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • benareeno
        Panasonic 50st30 plasma tv, where do I need to recap?
        by benareeno
        In order to get a proper picture from this plasma...I have to raise the gamma setting in order to see a balanced pic with proper black detail and lower the contrast setting in order to see all the proper levels of white...this could simply be phosphor wear or perhaps I need to address some caps somewhere on one of the boards??
        I had a crt projector years ago, and the recap I did make it seem so much better in several ways..should I consider doing this on this plasma? And if so, what board or boards should I do?
        02-05-2023, 12:08 AM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
