Panasonic 50st30 plasma tv, where do I need to recap?
  • benareeno
    • Jun 2021
    • 38
    In order to get a proper picture from this plasma...I have to raise the gamma setting in order to see a balanced pic with proper black detail and lower the contrast setting in order to see all the proper levels of white...this could simply be phosphor wear or perhaps I need to address some caps somewhere on one of the boards??
    I had a crt projector years ago, and the recap I did make it seem so much better in several ways..should I consider doing this on this plasma? And if so, what board or boards should I do?
  • Galraedia
    • Jun 2012
    • 7
    Re: plasma tv, where do I need to recap?
    What's the model of the plasma TV?
    • benareeno
      • Jun 2021
      • 38
      it's a Panasonic 50st30
      • benareeno
        • Jun 2021
        • 38
        and for what it's worth...it seems to be more prone to image retention these days. Could that be bad cap related?
        • Devil_rider
          • Jan 2023
          • 33
          Check the sustain voltages first . They might be off or they might need atweak to compensate for the age of the panel
          • benareeno
            • Jun 2021
            • 38
            Re: Panasonic 50st30 plasma tv, where do I need to recap?
            is that something that is adjustable via a pot?
            • Devil_rider
              • Jan 2023
              • 33
              Values are usually o the label of panel and adjusted with pots on the board . Pots should be labeled .
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                Check the screws that hold down the SC board. They may be coming loose. If you download the service manual you can enter the menu where you can adjust for aging. You can set the VS high or low. Elektrotanya.com has the manual.
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • stecos
                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                  by stecos
                  Hi everyone!
                  I happened several times, in the search for help from the web, to consult this very interesting forum.
                  So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                  Having said that I come to the gist of my post on the forum as the title suggests.
                  For my passion for technology I'm now collecting several...
                  11-28-2022, 11:39 AM
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
                • Eaglecrest
                  Panasonic plasma color stripe
                  by Eaglecrest
                  I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
                  11-05-2025, 06:16 PM
                • Alicat
                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                  by Alicat
                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                  Model number is TH-50PZ85U
                  Power comes on and the red power light stays on solid.
                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                  I also hear a few clicks.
                  I also think my parents said there was a thunderstorm and the TV failed after that.
                  Section 6 in the service manual talks about power and no screen,...
                  10-30-2024, 10:09 AM
