BenQ BL2400PT no backlight
+ More Options
Posts
  • meciu
    • Nov 2016
    • 37
    Hey!
    So starting yesterday - my old 24" LED display doesn't work well - device displays image but there is no backlight and I can hear hissing from power supply.
    I've tested lcd 6pin power cable and here are the :
    Black standby 0.4v power on 3.7v
    Brown standby 0.4 power on 3.4v
    Red standby 21.8v power on 28.9v
    Yelow stand by 0.4v power on 3.7v
    Green stand by 0.4v power on 4.8v
    Any ideas what's wrong with it?
  • meciu
    • Nov 2016
    • 37
    Re: BenQ BL2400PT no backlight
    Resistance test of (yellow) transformer 10pin
    P1 P2 3.5K Ω
    P1 P3 1.4MΩ
    P1 P4 0.2-0.5Ω
    P1 P5 200K-1MΩ
    P1 P6-10 0L
    P2 P3 0.3Ω
    P2 P4 39MΩ
    P2 P5 0.5Ω
    P2 P6-P10 0L
    P3 P4 6M-33MΩ
    P3 P5 0.3Ω
    P3 P6-P10 0L
    P4 P5 0.6M-1.5MΩ
    P4 P6-P10 0L
    P5 P6-P10 0L
    P6 P7+P8 0.18Ω
    P6 P9 0.16Ω
    P6 P10 0.16Ω
    Pin7 and pin8 are soldered together
    P7+P8 P9 0.12Ω
    P7+P8 P10 0.12Ω
    P9 P10 0.19Ω
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      do u check output capacitor and diode
      • R_J
        • 9551
        I doubt your problem is with the power supply, check the voltage on the led driver board.
        I suspect you have a problem with the led's themselves, Check the voltage going to the led's when you first turn on the monitor.
        • meciu
          • Nov 2016
          • 37
          This tested by me 6 pin cable is actually a LED power cable.
          So it is time for a LCD screen disassembly to check led diodes.
          • meciu
            • Nov 2016
            • 37
            Okay,
            Almost half of leds aren't working correctly.
            Question is - what kind of LEDs I need to look for.
            I assume that I need to find LEDs in 4 pin PLCC package (5x3x1mm) but which one?
            This led bar has two markings
            "AS-24M07005-N5HEX-X-1-11G-0057" and "N5HE"
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • DoorOfTime
              Sceptre X405BV -- Backlight on in standby?
              by DoorOfTime
              I have a sceptre x405bv TV with bad LED strips. The screen displays dimly over the good LED's, and on disassembling it looks like over half of them are dead tested by multimeter diode test on test points. Plugging it in with the panel disconnected (this TV has a combined power and main board), the backlights immediately receive power when the set is plugged in. When the power button is pressed, it flashes brightly then dims, but additional LED's turn or flicker. When it's turned off again some back lights stay on.
              Before I order replacement strips I wanted to ask if it is typical...
              04-04-2022, 10:13 AM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
