Xerox XA719i
  • Demix
    • Jul 2009
    • 72
    Xerox XA719i
    This is my last project monitor repair-wise, I had 5 monitors, fixed 2 destroyed 2 and now this is the monitor i wanted to actually use so im going to be extra careful with this one, Symptoms are the usual. Switches on for a few secs then blank but power light stays on, Backlights go out. errm.. it may be the CCFL's as when it is on for the few secs it is pretty dull but i cant get to them very easily so that will be my last resort... anyways i dont know where I can buy the replacement 2x2 ones that this screen has. Anyway I opened it up and recapped it.. but to my surprise this is the first monitor ive opened to find the massive cap bulging a little O.o picture attached. I wanted to know if i needed to replace this one and if so where can i get a replacement? lol the brand is ermm.. argh i will find it and reply with the brand shortly =P anyways yeah its bulging a little on the end which surprised me. Also when I opened it up i noticed on the underside of the pcb their was a black mark which looked like someone had fiddled with it but it was connected to a fuse :S (which i checked and was fine) so i think they may have been pretty clueless.. it may be ash from a cigarette as the whole screen STUNK of smoke when i got it. Anywho take a look guys, thanks ^^
  • PlainBill
    • Feb 2009
    • 7034
    Re: Xerox XA719i
    Second picture - Yes, it's bulging. Lift it up to find the size and voltage - it shouls be something like 100 µf, 450 Volt 105°C. This cap usually isn't a low ESR type; Digikey has them in stock for about $3.50. Check dimensions - that's a tight fit.
    Fourth picture. Those are inductors - they are a few turns of heavy gague wire wound on a ferrite core, then covered with heat shrink tubing. It would be extremely rare for one to fail.
    Failure. Resolder all the transformers. Also, try it in a dark room to see if anything arcs. If you haven't already done so, replace all electrolytic caps in the inverter.
    PlainBill
    • Demix
      • Jul 2009
      • 72
      Re: Xerox XA719i
      Okay i found out the cap was a 100uf 400V so you were very close PlainBill. I think ive found a suitable replacement for it as the measurements are almost the same and it matches as closely as it can - http://uk.rs-online.com/web/search/s...0575321#header also to my horror I noticed this on the underside of the PCB, it looks like someones been tinkering around and have unseated this lil thing. Im not sure what its called.. it looks intact but its been pushed about in the solder and isnt connecting properly by the looks of things O.o - http://terminalerror.250free.com/Doh.gif
      • Demix
        • Jul 2009
        • 72
        Re: Xerox XA719i
        Just because I know a lot of people wont want to download the gif image and infact in retrospec it was rather pointless me making it lol, so ive just stuck the images seperate and attached them below
        edit : also this bit is right near a transformer, i doubt the transformer would have got so hot it could melt solder though? unless its really crappy solder lol
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: Xerox XA719i
          looks like that is a shorted mlcc.
          only easy explanation for it getting that hot.
          • Wizard
            • Mar 2008
            • 2296
            Re: Xerox XA719i
            Clusmy solder guy did this kind of mess. Resolder and this ceramic capacitor as well. they will reflow nicely.
            Cheers, Wizard
            • Demix
              • Jul 2009
              • 72
              Re: Xerox XA719i
              thanks a bunch guys, im gonna reseat that lil ceramic cap and ive ordered the replacements for the small caps on the inverter side and the big 400v one so hopefully this should sort it all out =]
              • Demix
                • Jul 2009
                • 72
                Re: Xerox XA719i
                GRRRR this morning I opened up my good working monitor to test if the screen from the broken one was okay.... the ****in thing is cracked all at the bottom! whoever owned this before me needs a serious bloody slap! they messed it up big time... i mean it has protective glass how the **** did they crack the screen!?!?! idiots ¬_¬ now ive gotta not only finish fixing the inverter but now I have to find a 19" panel to replace this broken one with ¬_¬
                • Demix
                  • Jul 2009
                  • 72
                  Re: Xerox XA719i
                  Just wanted to know if anyone knew of anywhere I could pick up a M190E5-L0A (thats the panels model number) as i can only find it in like bulks of 500 and stuff =\
                    by momaka
                    03-15-2023, 10:17 PM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    10-30-2025, 04:45 PM
                  • wattage
                    AOC AG493UCX 49-inch monitor - Firmware request
                    by wattage
                    Hello Badcaps Community,
                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                    07-13-2025, 04:41 PM
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
                  • Rick_1234
                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                    by Rick_1234
                    Good evening, gentlemen.
                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                    Things I tried
                    - Bought a new AC adapter thinking that was the problem but the problem...
                    06-22-2024, 04:44 PM
