Bypass defective lamp?
  • lucky13
    • Aug 2007
    • 412
    OK, I've seen my share of LCD monitors where only one of the lamp is gone.
    Typically , the 4 lamp ones would have 2 lamps on top and 2 lamps on the bottom.
    So, if only one of the 4 is gone, the inverter still shuts off the lamps to prevent damage to the inverter board's transformers (from what I've read).
    There is over voltage protection and current sensing circuitry all built around the inverter IC.
    I have sub in a good lamp for the bad lamp outside of the LCD panel and found the brightness is not significantly reduced. heck, even subbed out 2 lamps still make the monitor quite usable.
    So my question is this. Is there a "simple" way to defeat the drive for one lamp or one set (i.e., 2 lamps) on the inverter board so it does not think there is bad lamp and shuts off all the light?
    This way, I can rig up quite a few monitors as usable instead of going to recycling.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Bypass defective lamp?
    Simple, good, or right?
    The simple way is to substitute an appropriate resistor for the defective lamp. At a guess, try something around 150K ohm, 5 watt.
    A good way would be to analyze the monitoring circuit and substitute the proper value resistors so it doesn't fail.
    The right way is to replace the bad CCFL.
    PlainBill
    • Krankshaft
      • Jan 2007
      • 2328
      Honestly though CCFLs aren't like UHP arc lamps in projectors that cost $250 bucks or more they are dirt cheap.
      Now for testing purposes to see if it's a bad CCFL I'm all for it.
      • PlainBill
        • Feb 2009
        • 7034
        There is one consideration - dexterity. I've known guys who could break anything they try to repair. Anyone with similar dexterity should NOT try to replace a CCFL.
        PlainBill
        • Krankshaft
          • Jan 2007
          • 2328
          If you can't remove and install a 2 terminal SMD component without tearing up traces then this isn't for you.
          I think the dexterity part is in that ballpark .
          • lucky13
            • Aug 2007
            • 412
            Hmm.. the lamp?
            I took one apart before to remove the lamp. The metal bracket no longer snaps tight. Needless to say, that was junked....
            Replacing the lamp isn't a big deal. Just the process of extracting it out of the lcd module and installing a good lamp back in. They don't screw together. They all have these metal points that snap tight!
            Hence my idea of just bypass the bad lamp.
            • PlainBill
              • Feb 2009
              • 7034
              Hmm.. the lamp?
              Yes, I understand. But it was a bad idea. With care an LCD panel can be disassembled and reassembled.
              PlainBill
              • Demix
                • Jul 2009
                • 72
                Yeah, i destroyed two screens today because I was being careless and its a mistake i will have learnt from, an expensive mistake though ¬_¬ one screen i took apart to swap over a CCFL to the other and i broke the ribons that were attatched. The other screen, the front slipped and yanked off the bit where the graphics boards wire is attatched. I know its not a very good example but yeah :P it isnt too hard aslong as you have the time and skill and your not in a clumbsy mood lol.
                • lucky13
                  • Aug 2007
                  • 412
                  PlainBill
                  And proper tools too! And extra hands....
                  • PlainBill
                    • Feb 2009
                    • 7034
                    The most involved I have found is the panel found in the Viewsonic VP211b. There are a lot of screws, brackets, etc to remove just to get down to the bare panel. At that point 'special' tools are needed. You need a flat tip screwdriver with a blade at least 3/8" wide. You need a '00' or '000' Philips screwdriver. And you need about a dozen round toothpicks (to keep the frame wedged away from the catches).
                    PlainBill
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      PlainBill
                      I agree. That VP panels are a pain to disassemble/reassemble.
                      You need to be VERY careful to do this kind of stuff
                      • ASUS ROG Maximus IX Code
                      • Intel Core i5-7600K 3.8GHz
                      • Windows 10 Pro x64
                      • GeForce GT1050
                      • lucky13
                        • Aug 2007
                        • 412
                        PlainBill
                        Thanks for the tip!! I will try that next time.
                        • Yanleb
                          Sharp LC-60LE810UN Lamp Error
                          by Yanleb
                          I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                          I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                          Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                          I've tried all the key...
                          08-24-2021, 11:48 PM
                        • x_orange90_x
                          by x_orange90_x
                          01-29-2025, 09:24 PM
                        • mikey5791
                          Help on Samsung Syncmaster T220 dead ccfl lamp
                          by mikey5791
                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                          10-18-2020, 03:17 AM
                        • vestaviascott
                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                          by vestaviascott
                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                          Here's what happens:
                          1) Power on
                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                          3) Blue status light flashes for appx 4 minutes...
                          07-29-2020, 06:08 AM
                        • Gentian
                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                          by Gentian
                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                          03-06-2023, 07:07 AM
